1954 239 Cam gear install
Y-BlocksForever Forum
Home      Members   Calendar   Who's On
Welcome Guest ( Login | Register )
1954 239 Cam gear installExpand / Collapse
Posted Wednesday, May 07, 2008 6:42 PM
Forum Newbie
Forum NewbieForum NewbieForum NewbieForum NewbieForum NewbieForum NewbieForum NewbieForum Newbie
Last Login: Saturday, August 09, 2008 1:21 PM
Posts: 4, Visits: 24
Ok guys here is what i have i,am a machine shop lost my pics of the engine when i took it apart. Any How i sent the cam out to get re-ground i need a pic with description of how the cam gear gets installed i looked at the one that was posted but what i need is the parts labeled. Parts i have cam gear spacer counter weight eccentric  bolt with washer.
When i put it together in this order retaining plate cam gear counter weight eccentric spacer washer with lock washer and bolt and tq. it up the cam locks up with no end play.
Mike
Post #12447
Posted Wednesday, May 07, 2008 7:14 PM
Supreme BeingSupreme BeingSupreme BeingSupreme BeingSupreme BeingSupreme BeingSupreme BeingSupreme Being
Last Login: Today @ 11:46 AM
Posts: 496, Visits: 6,425
It sounds like you are missing some washers.
See if this thread helps:
http://www.y-blocksforever.com/forums/Topic4349-3-1.aspx
Norcross, GA
Post #12449
Posted Wednesday, May 07, 2008 8:30 PM
Forum Newbie
Thanks for the link so there should be 2 spacers 6265 and 6287 how thick is the one that go,s be hind the cam. 6265 i beleave i have 6287
also what should the end play be on the cam and what is the cam bolt Tq. to.
Thank You
Mike
Post #12450
Posted Thursday, May 08, 2008 4:29 AM
Last Login: Today @ 9:22 AM
Posts: 857, Visits: 2,653
Mike:
The rear most spacer should be .002-.004 thicker than the thrust plate.  It also needs a generous chamfer to clear the radius on the cam snout.  If it was still on the cam when it went to the grinder, that's where it probably got lost, or in transit.
John
Post #12456
Posted Thursday, May 08, 2008 6:17 AM
Forum Newbie
John thank you i have established that i will give the cam .005 to .010 end play and will make the spacer since that is were it is at the cam grinder.
Thank you every one that helped on this.
Mike
Post #12458
Posted Thursday, May 08, 2008 7:32 PM
Forum Newbie
Made the spacer today .194 thick ended up with .006 end play on cam.
Spacer dimensions were .194 thick 1.350 OD. 1.015 ID.
mike
Post #12470
« Prev Topic | Next Topic »
Reading This TopicExpand / Collapse
Active Users: 0 (0 guests, 0 members, 0 anonymous members)
No members currently viewing this topic.
Forum Moderators: Jim, Ted
PermissionsExpand / Collapse
All times are GMT -6:00, Time now is 12:01pm
Powered By InstantForum.NET v4.1.4 © 2008
Execution: 0.125. 9 queries. Compression Enabled.
