T-Bird valve covers with Blue Thunder intake
Y-BlocksForever Forum
Home      Members   Calendar   Who's On
Welcome Guest ( Login | Register )
T-Bird valve covers with Blue Thunder intakeExpand / Collapse
Posted Sunday, May 11, 2008 6:50 PM
Forum Member
Forum MemberForum MemberForum MemberForum MemberForum MemberForum MemberForum MemberForum Member
Last Login: Yesterday @ 4:08 PM
Posts: 43, Visits: 357
Hey,
Just wanted to see if anyone out there has had a problem mounting T bird valve covers with the blue thunder intake installed? I tried to set some on, and i'm not being able to get these things to mount. ?? Anyone else?
My name is Greg and I am addicted to Y's.
Post #12525
Posted Sunday, May 11, 2008 7:31 PM
Junior Member
Junior MemberJunior MemberJunior MemberJunior MemberJunior MemberJunior MemberJunior MemberJunior Member
Last Login: Wednesday, July 16, 2008 6:09 PM
Posts: 16, Visits: 66
Hi Greg,
I have a BT intake on my 312, and even though I'm not going to use them, I did mount a set of T-Bird covers on it, and there was no problems.  The external dimensions of the BT are the same as the stock '57 Y-Block 4 barrel intake.
Larry D
Winnipeg, MB Canada Eh!
'57 Fairlane 500 Club Victoria
'58 Custom 300 Tudor
'56 Crown Victoria Skyliner (Clone)
'61 Starliner Z Code
Post #12528
Posted Sunday, May 11, 2008 9:00 PM
Supreme BeingSupreme BeingSupreme BeingSupreme BeingSupreme BeingSupreme BeingSupreme BeingSupreme Being
Last Login: Today @ 2:29 PM
Posts: 457, Visits: 5,984
I'm using aftermarket finned valve covers.  I had to do a little grinding on the driver side cover, toward the rear, below the bellcrank mounting boss.  It's nothing major.  The passenger side was fine.
Norcross, GA
Post #12532
Posted Sunday, May 11, 2008 9:42 PM
Last Login: Tuesday, August 05, 2008 9:42 PM
Posts: 133, Visits: 1,562
Hey Greg;  Yes I have the Blue Thunder manifold and had to whittle a little on the drivers side cover (Alun. T-Bird covers)  anyway take a little off the edge at the runner by the throttle bell crank. Doesn't take much!!  Hope this helps!!  God Bless
Eddie
Lake Forest, Ca. 92630
Post #12533
Posted Monday, May 12, 2008 5:46 AM
Co-AdministratorCo-AdministratorCo-AdministratorCo-AdministratorCo-AdministratorCo-AdministratorCo-AdministratorCo-Administrator
Last Login: Today @ 5:08 AM
Posts: 788, Visits: 1,101
Aluminum or Thunderbird valve cover fit with the Blue Thunder intake seems to get more critical as the heads are milled.  If dry fitting everything, it’s easier for myself to mill or grind on the intake where the interference occurs.  Now knowing that an interference problem can arise, I simply check the fit before bolting down the intake and modify the manifold as deemed necessary rather than modifying the valve covers.
Lorena, Texas  (South of Waco)
Post #12536
Posted Thursday, May 15, 2008 10:22 PM
Forum Member
Thanks guys, problem solved...
Post #12631
« Prev Topic | Next Topic »
Reading This TopicExpand / Collapse
Active Users: 0 (0 guests, 0 members, 0 anonymous members)
No members currently viewing this topic.
Forum Moderators: Ted
PermissionsExpand / Collapse
All times are GMT -6:00, Time now is 2:33pm
Powered By InstantForum.NET v4.1.4 © 2008
Execution: 0.172. 12 queries. Compression Enabled.
