| | | Supreme Being
Group: Forum Members Last Login: Yesterday @ 8:16 PM Posts: 434, Visits: 1,582 |
| | Darn - I forgot, 1954 - this is a Load-o-Matic distributor isn't it? How are you feeding the two vacuum cans off the three carbs I saw in your photos?
Steve Metzger Tucson, Arizona |
Forum Member
Group: Forum Members Last Login: Monday, November 10, 2008 5:28 AM Posts: 49, Visits: 349 |
| | Hi Pete & Steve, No time to work on it tonight . The part # on the box is 1282N6 & it also says 8 cyl 6 V neg ground. I bought this one because I just have 6 volts going to the points & Because the mounting of it has the straight base that my points had. I have another petronics from a latter model y-block 12 v that won't fit. The engine is a 55 272 ford. When my points burnt out I couldnt find any that had a straight base. This Saturday Mechanic is still stumped ! I only have the center carb hooked up and I have the vacuum hooked to that to the Advance on the Distributer. Pete I will call petronics when I get a chance. My next step is to put points back in it for now. There is a 3 day car show in Lake George, Ny which is the next town from me. Might just run My Galaxie. Anyhow Thanks, Mike
