½” Head bolt capability
Y-BlocksForever Forum
Home      Members   Calendar   Who's On
Welcome Guest ( Login | Register )
½” Head bolt capabilityExpand / Collapse
Posted Friday, January 04, 2008 7:35 AM
Co-AdministratorCo-AdministratorCo-AdministratorCo-AdministratorCo-AdministratorCo-AdministratorCo-AdministratorCo-Administrator
Last Login: Yesterday @ 6:09 AM
Posts: 762, Visits: 1,091
Heads need to be able to use ½” head bolts.  Stock factory heads can be drilled without hitting water so that ½” head bolts can be used.  Likewise should be the same with any aftermarket replacement heads.  One idea is for the head bolt holes to be ½” except for a shoulder at the top to accommodate a 7/16” head bolt.  If using a ½” head bolt, then the shoulder is simply drilled out.  This feature is already on a variety of the SBF aftermarket heads so the heads can be used on either 302’s or 351W’s.
Lorena, Texas  (South of Waco)
Post #9143
Posted Monday, March 03, 2008 2:12 PM
Supreme BeingSupreme BeingSupreme BeingSupreme BeingSupreme BeingSupreme BeingSupreme BeingSupreme Being
Last Login: Tuesday, July 22, 2008 11:14 AM
Posts: 282, Visits: 503
If you drill out a threaded 7/16 hole in the block to the recommended bit size for a 1/2" tap, will the bit remove all of the 7/16 threads to leave a clean hole to tap to 1/2"?
Post #10572
Posted Monday, March 03, 2008 4:26 PM
Last Login: Thursday, July 17, 2008 4:12 AM
Posts: 222, Visits: 1,740
The recommended way is to just run the 1/2" tap into the 7/16" threaded hole. John has used this method and states that it worked fine.
Glen Henderson
Freedom is not Free
Letohatchee, AL
Post #10575
Posted Monday, March 03, 2008 5:26 PM
Thank you for that info, Glen.
Post #10577
« Prev Topic | Next Topic »
Reading This TopicExpand / Collapse
Active Users: 0 (0 guests, 0 members, 0 anonymous members)
No members currently viewing this topic.
PermissionsExpand / Collapse
All times are GMT -6:00, Time now is 3:20am
Powered By InstantForum.NET v4.1.4 © 2008
Execution: 0.188. 13 queries. Compression Enabled.
