9 inch rearend
Y-BlocksForever Forum
Home      Members   Calendar   Who's On
12»»
9 inch rearendExpand / Collapse
Posted Saturday, February 09, 2008 7:02 PM
Supreme Being
Last Login: Today @ 7:23 PM
Posts: 103, Visits: 10,860
What would be a good place or vehicle to find a nine inch that I can put in my '56 customline?
Jan  Urbanczyk  Major USMC Ret.
        Bowie Maryland
        Bowie, Maryland
Post #10043
Posted Saturday, February 09, 2008 7:26 PM
Supreme Being
Last Login: Today @ 5:14 PM
Posts: 127, Visits: 1,560
57, 58, and 59 ford cars.  Lincoln Versailles (already has disc brakes), some Granadas and Monarchs.
You gotta have the right tools and know how to use them.
Rocklock - Austin, Texas
Post #10044
Posted Saturday, February 09, 2008 7:39 PM
Supreme Being
Thanks, Tom.  I always like to talk to fellow Texans.
        Bowie Maryland
        Bowie, Maryland
Post #10046
Posted Saturday, February 09, 2008 9:55 PM
Supreme Being
Last Login: Yesterday @ 6:58 PM
Posts: 781, Visits: 1,477
Cactus,
          If you're running an automatic, and only on the street, you can also use an 8' from an early 60's Mustang or Fairlane. They're fairly strong and generally cheaper. But you'll have to convinve most owners that they are NOT a nine inch and not worth $200,000!
Post #10049
Posted Sunday, February 10, 2008 1:24 PM
Supreme Being
I am running a moderately breathed on 317" motor with a T-5, and I am just a little concerned with the durability of the stock rearend.
        Bowie Maryland
        Bowie, Maryland
Post #10060
Posted Sunday, February 10, 2008 3:20 PM
Supreme Being
Jan,
        A well set up 8" will easily handle 300 hp. Late model 8.8's in the Fox bodies are common and inexpensive also. You'd need to remove the control arms and brackets and weld on some leaf spring brackets, but that's not impossible. If you use a 57 58 or 9 rear end, you might want to replace the pumpkin with a later big bearing unit. the '57 parts were not very strong.
Post #10061
Posted Sunday, February 10, 2008 3:57 PM
Supreme Being
Last Login: Yesterday @ 9:09 AM
Posts: 114, Visits: 638
Catus Y-Guy   You might try looking at Explorer rear ends. I just pulled
                     two from"Pull-A_Part" junkyard. They are 53" from B.P.
                     to B.P. and already have leaf perches plus you can get
                     ratio's from 3.08,3.55,3.73 and 4.10. When you look at
                     the rear end tag, If there is an "L" between the numbers
                     (example 3L73) then its a posi-unit. You can get these
                      for 65-85$$ with drums or disc w/caliphers!!! The 8.8
                      is plenty tough for our Y's and they are lighter plus
                       90% will be 31 spline.... Thx Bill
Bill
Pelham,Al
Post #10063
Posted Sunday, February 10, 2008 5:16 PM
Supreme Being
Last Login: Today @ 7:27 PM
Posts: 796, Visits: 4,914
Problem with explorers they are usually 5 on 5.5" bolt patterns. You can buy replacement axles with a 5 on 4.5" but they are a couple hundred dollars. Chuck in NH
 MoonShadow, 292 w/McCulloch 28 Chrysler Roadster (mystery motor)
Post #10065
