max streetable hp with Y block
Y-BlocksForever Forum
Home      Members   Calendar   Who's On
««123»»
max streetable hp with Y blockExpand / Collapse
Posted Friday, February 15, 2008 4:34 PM
Supreme Being
Last Login: Yesterday @ 6:58 PM
Posts: 781, Visits: 1,477
The bonnet would work, Fits a Holley or Demon by rotating it off to the side to miss the floats.
Post #10218
Posted Saturday, February 16, 2008 5:28 PM
Supreme Being
Last Login: Today @ 6:45 PM
Posts: 248, Visits: 1,281
Matt, making 400+ hp is very doable in a y-block. Good head work, Intake , Cam selection, carb, and a good balance job on your mill you should be able to drive it anywhere and to the strip. Come to Columbus Oh. this labor day week end and watch these guys run!!! Watching Frank, John, and Vic in their impressive machines is all it takes.
-Gary Burnette-
Post #10246
Posted Sunday, February 17, 2008 2:13 AM
Junior Member
Junior MemberJunior MemberJunior MemberJunior MemberJunior MemberJunior MemberJunior MemberJunior Member
Last Login: Saturday, March 15, 2008 5:07 PM
Posts: 20, Visits: 70
I would love to make it to Colombus and have some fun. Have to see if I can get off from work, I have plenty of time to try though. Hopefully I'll have mine started by then. Planning is always fun. There are just too many choices when it comes to engines. Thanks for all of the input every one.
Don't get mad, don't get even, get far, far, far ahead..
Matt, Maryville, TN
Post #10250
Posted Sunday, February 17, 2008 6:32 PM
Supreme Being
Conrad,
  Gary's being a little modest here, his UNBLOWN bird runs very low 13's at over a 100 mph. It's also street driven. If you're around North Carolina be careful picking on old black Thunderbirds, you may get a surprise!!  He won the Y Block shootout at Columbus last Labor day with it against some fairly serious racers.
Post #10266
Posted Friday, February 29, 2008 4:17 PM
Forum Member
Forum MemberForum MemberForum MemberForum MemberForum MemberForum MemberForum MemberForum Member
Last Login: 2 days ago @ 2:24 PM
Posts: 37, Visits: 199
speedpro56 (2/16/2008)
I am hoping for eventual 450 at the wheels with a lot of boost and some serious headwork.  Hopefully not too many busted parts...
James Potter
`57 Fords International
Twin Turbo 292 in process....
Toploader 4 speed
Aiming for psychotic notoriety in the deep south.
Post #10496
Posted Saturday, March 01, 2008 9:57 AM
Junior Member
Sounds like a lot of fun James. twin turbo yeah. Hope to see alot of coverage on this engine build. I think I just found the bones for my engine today. Local guy has a C2AE for $400, might be able to barter it off of him. Would rather spend my cash on speed items. Are the C1TE heads worth building for a boosted engine or should I try and find the 5750 heads?
Matt, Maryville, TN
Post #10516
Posted Saturday, March 01, 2008 10:58 AM
Supreme Being
Last Login: Today @ 7:00 PM
Posts: 857, Visits: 2,658
Matt:
C1TE heads have the same chamber volume as 471s but have smaller intake valves.  I have put the 1.94 valves in them and used them on my blown car, saw no performance difference between them and the stock blower heads.  I opened the bowl area to match the bigger valves.  I had to use spark plugs without extended tips, as the intake valves would hit the ground electrode of an extended tip plug.
John
Post #10518
Posted Sunday, March 02, 2008 12:52 AM
Junior Member
The guy who has the C2AE also has an EDB block that was sent to the machine shop left std bore, new cam bearings installed, polished, cleaned up, etc...Anyways, I was wondering if I should pick it up off of him and use it with C2AE parts, due to it probably being made of thicker cast? For $50 seems a shame not to. any opinions?  (He said that the EDB crank couldn't be re-used though...egg shaped or something? would there be concern as to the block's main crank journal area? the surfaces looked fresh.) He also has ECZ 4bbl manifold, what would you offer for it?
Matt, Maryville, TN
Post #10541
Posted Tuesday, March 04, 2008 6:34 AM
Co-AdministratorCo-AdministratorCo-AdministratorCo-AdministratorCo-AdministratorCo-AdministratorCo-AdministratorCo-Administrator
Last Login: 2 days ago @ 5:47 AM
