Stock Fuel Pump
Y-BlocksForever Forum
Home      Members   Calendar   Who's On
««123»»
Stock Fuel PumpExpand / Collapse
Posted Tuesday, April 22, 2008 1:49 PM
Supreme Being
Last Login: Today @ 3:47 PM
Posts: 299, Visits: 3,197
As I recall the stock bird pump has the bottom part of the pump rotated to allow the inlet/outlet to clear the front crossmember. Something you should be able to do do on the FE pump too. ?
Alan Frakes ~ Tulsa, OK
Post #12002
Posted Tuesday, April 22, 2008 2:13 PM
Supreme Being
Last Login: Today @ 9:45 AM
Posts: 391, Visits: 1,273
According to the Holley information on their 80GPH pump (that looks just like the #362 Airtex to me) - you can "clock" the lower housing to suit the required inlet/outlet angle. In any case Gary must have overcome this on his '56 so...........
One thing I did notice about the Holley parts sheet - it says (*) the inlet and outlet ports are 1/4 NPT - and all of the other 80 GPH pumps say 3/8 NPT. It must be becasue of the factory Ford fittings its supposed to be used with on the 428 FE. Inverted flares no doubt. So -----if a guy wanted a lower housing with more flow potential - you'd have to swipe one off a chebbie or other suitable boatanchor.
                               Steve Metzger               Tucson, Arizona
Post #12005
Posted Tuesday, April 22, 2008 5:23 PM
Supreme Being
Last Login: Tuesday, September 02, 2008 9:49 PM
Posts: 135, Visits: 1,594
Hey Steve;  Had same problem, only single, no vac ports,.  Shimmed up front mount 2 washers, also adjusted steady mounts up some.  Pump is a Carter with anew design ( tin bottom).  Hope this helps and hope this gets to you have not been able to login all this week!!   God Bless    Eddie
Eddie
Lake Forest, Ca.
Eddie
Lake Forest, Ca. 92630
Post #12008
Posted Tuesday, April 22, 2008 6:35 PM
Supreme Being
Last Login: Today @ 6:45 PM
Posts: 248, Visits: 1,281
Yep! gas line from the tank too the fuel pump on the bird is 5/16. The #362 cleans up the area around the pump as well.
-Gary Burnette-
Post #12011
Posted Sunday, April 27, 2008 8:53 AM
Supreme Being
The Airtex #362 pump arrived and I rounded up enough fittings and tubing to put it on there yesterday. Came out OK I think, still haven't installed any of the pushrods so I'll wait to start it later. The inlet and outlet are 1/4 NPT and positioned toward the left rear if you just take it out of the box and try to put it on there. The pump lever pivot is located way closer to the flange face than the Bird pump, which makes the diaphragm move farther with each stroke and jumps up the volume.
Turning the inlet/outlet to the "right" position is a case of learning by trial and error. There are 10 scews so you have a few choices to sort out. Mine finally ended up so that the outlet is 36° left of dead ahead. When you take the bowl screws out - be prepared for the diaphragm to disengage from the operating levers and fall out of the dumb thing (could be that the dummy is talking here). Getting the devil back together is a case of "learning to hold your mouth right" - a phrase I learned from a banjo picking friend.
My advice (if yours falls apart) is to carefully remove the small diameter lever return spring (directly under the operating lever) - it can fly and will also fight everything you try to do. Then wrap a rubber band around the operator lever to hold the smaller lever inside (that actually engages the slot in the diaphragm operating rod) out into a position where you can actually maneuver the rod back into engagement. Once you've got it back engaged, subsitute the lower bowl for the fingers you have holding the diaphragm. It helped me to find three screws that matched the bowl screw threads - but were about 3/4 inch longer - to start it all back together. After a few trials you will either get good at this or resort to drinking. When everything is back as it should be - cut the rubber band and reinstall the return spring.
Test it one last time before you bolt it in - to be sure it has stayed together internally and will actually pump.
The 90° double flare fittings I found had tiny internal passages and I opened them up as much as I dared by drilling. Also did a bit of "porting" on the inlet elbow to make sure I didn't build in a suction restriction. You can reduce pump efficiency more easily on the intake side than the pressure side. The rule of thumb for hydraulic pumps is usually to make the suction side twice the size of the pressure side - and that holds for this type of pump too.
Yeah, I know - the rear upper A-arm bushing is trashed.....
Post #12138
Posted Monday, April 28, 2008 11:17 AM
Supreme Being
Last Login: 2 days ago @ 9:56 AM
Posts: 211, Visits: 445
FYI, Steve or anyone else that is interested, I just bought one of those Holley 80 gpm fuel pumps (7.5psi) last weekend after I notice my car surging. Determined it was the fuel pump as my clear fuel filter by the carb would fill 3/4's of the way and then bubble down to almost empty. I suspected a rip in the diaphram of the stock dual vacuume pump. I asked for a fuel pump to fit a 390 at a local speed shop and they gave me the Holley. In the written instructions, it lists Y-Blocks and all FE motors. It works great, car runs perfect!
On another note, I still have the vacuume wipers and just plugged them into an intake port. They work fine too, no difference from being hooked up to the fuel pumo!
Rob
Post #12180
Posted Monday, April 28, 2008 11:37 AM
Supreme Being
Last Login: Today @ 7:27 PM
Posts: 796, Visits: 4,914
I've been using the Holley high performance pump for a 427 FE for years. Plenty fuel pressure and chrome too! Chuck in NH
 MoonShadow, 292 w/McCulloch 28 Chrysler Roadster (mystery motor)
Post #12182
Posted Saturday, May 03, 2008 11:51 AM
Supreme Being
Last Login: Today @ 6:16 PM
Posts: 101, Visits: 260
Iv been followign this thread with great interest.  Ive long had the suspicion that my pump isnt keeping up.  It cant keep the glass filter bowl full, and it stumbles for a fraction when I floor it in passing gear, even having gone to much higher jets and lower power valve, etc.  (New plugs, wires, cap, rotor, timing good (although total advance seems a bit high at around 50 deg; 10 deg initial) pertronix, etc., engine only has 10k miles on it, holley 390 carb with a little bigger cam).  Could low fuel pressure be the culprit?  Is having to go to much bigger primary jets out of the box on this carb possibly due to low fuel pressure/volume?  Most people around here seem to have most carbs work great right out of the box....
IF so, would any 390 or 427 pump work, like these:
http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM%2D250006%2D1&N=700+115&autoview=sku
http://store.summitracing.com/partdetail.asp?autofilter=1&part=HLY%2D12%2D832&N=700+115&autoview=sku
http://store.summitracing.com/partdetail.asp?autofilter=1&part=CRT%2DM4008&N=700+115&autoview=sku
I dont need the vacuum pump portion, but would prefer something that is NOT chrome.  So does it seem like fule delivery might be the issue, and if so, are these (or any others?) good options?
Sorry for the simple question, but Ive forgotten what little I knew about tuning carbs, and NOBODY around here knows squat about how to open a hood.
THANKS!!!!
ron
Post #12332
