load o matic or not
Y-BlocksForever Forum
load o matic or not Expand / Collapse
Posted Thursday, November 09, 2006 3:00 PM
Supreme Being
Last Login: Today @ 11:23 AM
Posts: 155, Visits: 274
hey guys. names eric. just became a new member.  now tot the question. I have a 1964 ford f100 with a 292. does this motor have the load o matic setup on it. if not what kinda advance system does it probably have. the distibutor is a single points one.
Post #1202
Posted Thursday, November 09, 2006 3:51 PM
Supreme Being
Group:
Last Login: Friday, July 24, 2009 7:25 AM
Posts: 158, Visits: 1,076
If the engine is original you do NOT have a Load O Matic and be thankful.
Brodie
Savannah, GA
Post #1204
Posted Thursday, November 09, 2006 6:01 PM
Co-AdministratorCo-AdministratorCo-AdministratorCo-AdministratorCo-AdministratorCo-AdministratorCo-AdministratorCo-Administrator
Last Login: Friday, February 03, 2012 5:43 PM
Posts: 3,130, Visits: 2,148
You can check out the points in the distributor for a quick check to see if you have the early (pre-57) or late ('57 and later) distributor.  If the points are curved, you've got the late and if the points are straight you've got the early.  Also, if you can see any advance springs with the distributor cap pulled loose, you've got the early.  The late model distributor has the advance springs under the breaker plate where you can't see them very easily.
Like 55Brodie said, the truck originally came factory equipped with the 'late' distributor but 40+ years after the fact, any thing could have changed.
Lorena, Texas  (South of Waco)
Post #1208
Posted Friday, November 10, 2006 8:45 AM
Supreme Being
thanx guys. so then this distributor is vaccum and centrifical advance then?
Post #1212
Posted Saturday, November 11, 2006 8:01 AM
The distributor potentially could have been replaced with an 'early' unit somewhere along the line so you've still need to verify that you have the correct 'late' distributor in the engine.  The 'late' distributor is physically larger in diameter but if you're not adept at recognizing the differences in sizes, you'll need to pull the cap and check.  The 'late' distributor will have curved points, the advance springs under the breaker plate assembly, and the rotor will turn against the mechanical advance spring resistance CCW when you put pressure on it.  If you've got all these, then the distributor will indeed have both a mechanical advance and a vacuum advance whereas the 'early' or Load-O-Matic distributors are vacuum advance only.
Also, if using a timing light, the 'late' distributor will show a given amount of advance on the damper when speeding up the engine with the vacuum advance line disconnected if the mechanical advance curve is not 'froze' up.  I'd use the aforementioned methods of identification before doing this one as a frozen advance curve can send you off in the wrong direction.
Post #1228
« Prev Topic | Next Topic »
All times are GMT -6:00, Time now is 5:31pm
Execution: 0.078. 7 queries. Compression Disabled.
