Supreme Being
Last Login: Today @ 6:39 PM
Visits: 28,829
Concerning the NHRA regulations, does the capacity matter?
Supreme Being
Last Login: Monday, May 14, 2012 7:49 AM
Visits: 788
| Charlie, I don't believe so. I currently run a Moon catch can, but when I ran my Model A and it would not pass tech due to the lack of a catch can, we attached an empty "tall boy" beer can to the rad, via a gear clamp. It passed tech and contunued to do so for several years after at many different tracks. I left it there as my good luck charm, seemed to work too!  Rob
Supreme Being
Last Login: Friday, May 11, 2012 10:54 AM
Visits: 393
| Yes, the NHRA 2008 rulebook specifies 1 pt. (16 oz) minimum. I use a 1 qt plastic oil bottle, tie wrap it to the radiator support and then run a length of rubber hose from the neck to inside the bottle. I use a black bottle to blend in with the rad support. Regards, Dennis
Supreme Being
Visits: 28,829
Alright, thanks. I have my eye on a pint sized catch can.
Supreme Being
Last Login: Today @ 2:10 PM
Visits: 7,169
| I have a 16 oz laundry fabric softener bottle mounted upside down with a hole in what is now the top for the overflow hose. I can unscrew the cap to drain the bottle without removing it from its mount. John in Selma, IN
Supreme Being
Last Login: 2 days ago @ 12:02 PM
Visits: 1,327
I used the original(repo) "See-Clear" windsheild washer bag! It look like it should be there and works perfect. Sure looks better than any plastic bottle. You can get repos cheap too. I had to remove the check ball in the bag cap, run a hose to the overflow at the rad. cap, and put a low pressure cap on the radiator
Pat Fleischman
Supreme Being
Last Login: Today @ 5:16 PM
Visits: 3,024
| Charlie, most of the parts stores have "Kits" fo $10 or $15. paint the bottle/can black like dennis said, pisses the techs off when they can't find it!
Supreme Being
Visits: 28,829
| I went with a 28oz Meziere Recirculating tank. Now I just have to find a radiator cap that will allow me to use the recirculating function. Do y'all think this will pass tech? Will they want hose clamps?
I also put a 1" longer spacer on the fan. I'm hoping it will alleviate an idle temperature creep-up condtion since I will not have any time to try to fix those sorts of problems before Columbus.
Supreme Being
Visits: 3,024
| Charlie, The catch can's good. Don't get the fan too close to the rad, the engine can move forward on the mounts some.
Supreme Being
Visits: 28,829
Excellent. One step closer. The fan's still an inch or 2 away frome the radiator. I think it said in the instructions to make sure there is at least 1/2" of clearance.
