WANTED vacuum advance for dist
Y-BlocksForever Forum
Home      Members   Calendar   Who's On
WANTED vacuum advance for distExpand / Collapse
Posted Monday, May 05, 2008 11:32 PM
Forum Newbie
Forum NewbieForum NewbieForum NewbieForum NewbieForum NewbieForum NewbieForum NewbieForum Newbie
Last Login: Sunday, October 05, 2008 12:20 PM
Posts: 8, Visits: 42
Hi i need a vacuum advance unit for 292 1958 distributor as i live in england we do not have a pep boys or napa store             thanks mark
Post #12404
Posted Tuesday, May 06, 2008 7:57 AM
Supreme Being
Last Login: Yesterday @ 4:47 PM
Posts: 335, Visits: 734
e-mail John Wilson in Alabama. He has tons of parts mat be able to help you. snowbird312@hotmail.com tell him I gave you his address. Dave (I am the guy with header fit problems)
55Birdman
Post #12414
Posted Tuesday, May 06, 2008 11:49 AM
Supreme Being
Last Login: Today @ 5:15 AM
Posts: 408, Visits: 1,375
Does it look like this one - with the screw-in cover and tapped hole for the steel vacuum line fitting?
Be sure and tell them which one you need - there is another vacuum pot with a "nipple" on the port that accepts a push on hose.
                               Steve Metzger               Tucson, Arizona
Post #12416
Posted Tuesday, May 06, 2008 10:05 PM
Supreme Being
Last Login: 2 days ago @ 9:29 PM
Posts: 373, Visits: 814
verr: You don't have a vacuum advance? Or it does not work? If you have it, what carb are you using? Is it hooked up to the carb or mainifold? Details?
Post #12428
Posted Wednesday, May 07, 2008 5:47 AM
Co-AdministratorCo-AdministratorCo-AdministratorCo-AdministratorCo-AdministratorCo-AdministratorCo-AdministratorCo-Administrator
Last Login: Today @ 5:54 AM
Posts: 919, Visits: 1,152
verr1908 (5/5/2008)
Assuming you need the vacuum advance chamber with the crooked arm, then the vacuum chamber from a ’58 or later 352 or 390 should also work as well as the chambers for the small block Ford (221/260/289).  The spring tension in the chambers may not be exactly the same thereby making for a slightly different vacuum advance curve but that isn’t expected to be a show stopper on a Y.  But nothing guarantees the replacement vacuum chambers being the same in spring tension anyhow as they tend to be pretty generic to fit a wide application of vehicles.  Just be sure to carry your old one with you to the parts store to insure that you are getting a chamber that physically looks the same.
Lorena, Texas  (South of Waco)
Post #12434
« Prev Topic | Next Topic »
Reading This TopicExpand / Collapse
Forum Moderators: Ted, Hoosier Hurricane
PermissionsExpand / Collapse
All times are GMT -6:00, Time now is 11:59am
Powered By InstantForum.NET v4.1.4 © 2008
Execution: 0.172. 13 queries. Compression Enabled.
