| | | Forum Member
Group: Forum Members Last Login: Today @ 1:29 PM Posts: 27, Visits: 113 |
| also wanted to know if the Y block starter would interchange with late model flathead.
if i'm converting to 12V, might as well do it all.
thanks!
This ain't no L-Kamino! |
| | | | Supreme Being
Group: Forum Members Last Login: Today @ 5:26 PM Posts: 854, Visits: 2,632 |
| | Davis: The Y starter mounts with three bolts in the flange at the drive end of the starter. If I remember correctly, flathead starters mount with two bolts through the starter itself. The 6 volt wtarter will work on 12 volts, it actually has bigger windings in it that the 12 volt one has. John in Selma, IN
| | | | Forum Guru
Group: Forum Members Last Login: Yesterday @ 10:52 PM Posts: 68, Visits: 789 |
| | Gents, Isn't the Yblock starter just a flathead starter with a alloy 3 bolt adapter attached by the two original flathead mounting bolts? is what I was led to believe.
__________ \_((__________))_/ (£ )_____v_____(£) [____l______l____] [_] ¢ ¢ [_] Dutchy - Christchurch - New Zealand |
| | | | Supreme Being
| | Dutchy: I just compared the two, the case lengths are the same, but the Y starter is about 3/4" longer from the back end of the case to the tip of the shaft. The flathead armature may fit in the Y case though. John in Selma, IN
| | | | Forum Guru
| | Thanks John, That myths busted!!!!
| | | | Supreme Being
Group: Forum Members Last Login: Today @ 6:12 PM Posts: 139, Visits: 795 |
| | I don't know if you want to spend this much but I got a flyer from joblot auto(joblotauto.com) in NY and they have brand new(no core required)flathead starters in 6 and 12 volt for $169.00 plus shipping.They also have front control arm kits which do upper and lower arms complete with shafts,all bushings, and lower bolts for $115.00 for 54-56 Ford cars and 55-57 Tbird if anyone is looking for these items.Regards Mark |
