Rough start
Y-BlocksForever Forum
Home      Members   Calendar   Who's On
«««1234
Rough startExpand / Collapse
Posted Friday, June 27, 2008 5:36 AM
Supreme Being
Last Login: Today @ 8:46 PM
Posts: 139, Visits: 816
Hello Andrew,You might want to get the print catalogue from Tee-Bird.The choke tube setup(original type) is shown in a diagram in the catalogue.I believe that all parts required are available from them.They also list a tool to remove old pipe from manifold.I assume it can be done on car.Part# 9890T under tools.$10.00.If you have never looked at one of their catalogues I think you will be very surprised at the # of parts they have for 55-56 Fords.Well worth the $5.00 cost.I just found my catalogue tonite(Friday)All parts needed to put original choke tube hookup are available from Tee-Bird.Total cost for 6 items is about $40.00.Plus the tool mentioned earlier if you want to try it without taking manifold off.Regards Mark
Post #13915
Posted Friday, June 27, 2008 10:56 PM
Forum Member
Forum MemberForum MemberForum MemberForum MemberForum MemberForum MemberForum MemberForum Member
Last Login: Sunday, August 10, 2008 8:27 PM
Posts: 40, Visits: 152
Thanks for the tip, I went and pulled out my catalog and made a list of all the parts.  The diagram was exactly what I needed to see to understand what it should all look like.
I think I'll probably just pull the manifold so it will be easier and I'll have a better chance of not bending the tubes.  I also have the new carb insulator I want to put on so I'll just take a day when I get the parts and tear it all down and do it right.
I'll give them a call tomorrow and get the parts on the way.  If I do pull the intake, should I replace the gaskets? I assume so but the motor only has 1400 miles on it so do you think they may still be reusable?
Thanks again to all you for your advice, suggestions and wisdom.  I owe you all most of the credit in the restoration of this car, I can assure you it wouldn't be on the road without you
Andrew 56-Vicky
Post #13946
Posted Saturday, June 28, 2008 4:42 AM
Supreme Being
Last Login: Today @ 2:15 PM
Posts: 227, Visits: 1,915
Andrew
  The intake maniflo gaskets are composite. would not try using them again. NAPA has them for around $10
Tm
 TOM in  Bethel ,Vermont
aka: Bluedot Kid
School of Hard Knocks C l a s s of 1960
Post #13949
Posted Saturday, June 28, 2008 6:06 AM
Supreme Being
Andrew,Tee-Bird has a listing for the intake manifold gaskets with restrictor to cut off the heat passage from head to head.Part # 9433A-SP $15.00.Might help your carb problem but not sure if it affects heat to carb choke tube.Maybe someone else will know.Just thought i would mention it.It is listed in "engine parts" section if you want to read it.regards Mark
Post #13950
Posted Saturday, June 28, 2008 3:02 PM
Forum Member
Thanks!
They also show the $40 carb spacer listed for PCV... John, is this the spacer you were talking about that might help with heat transference to the carb?  Or do you think that asbestos gasket I bought will do the trick?
Andrew 56-Vicky
Post #13962
Posted Saturday, June 28, 2008 4:24 PM
Supreme Being
Last Login: Today @ 7:00 PM
Posts: 857, Visits: 2,658
Andrew:
The spacer I was referring to was the factory spacer.  It is 1/2" thick and made of a phenolic like material.  Your asbestos gasket would be a help.  I'm not sure what the pcv spacer is made of, but if it's aluminum it isn't nearly as effective as phenolic or asbestos.
John
Post #13963
Posted Monday, June 30, 2008 9:21 PM
Supreme Being
Hello Andrew,There is one of these spacers on Ebay.Used item#310063231829 if you are interested.Regards mark
Post #14026
Posted Tuesday, July 08, 2008 8:52 AM
Forum Member
I just got back to town after the 4th and missed the one above on Ebay. I found this one 170227953855 that is 1" thick made of phenolic.  But I'm not sure if it will work with the 56 T-pot or not.
Also it is 1", is that better or worse for performance than a 1/2".  No one has ever explained the purpose of a spacer to me
Will the original air cleaner still clear the hood with a 1" spacer?
Thanks again guys!!
Andrew 56-Vicky
Post #14261
« Prev Topic | Next Topic »
«««1234
Reading This TopicExpand / Collapse
Active Users: 1 (1 guest, 0 members, 0 anonymous members)
Permissions
