| | | Supreme Being
Group: Forum Members Last Login: Yesterday @ 4:21 PM Posts: 231, Visits: 1,808 |
| Frank, I'm late with replying, but I got the brackets for my 62 F100 from Classic Performance Products (714) 522-2000 in Anaheim, CA. The kit has brackets and mounting hardware, uses 70's ford rotors and GM calipers. The kit is $85.00, I got the rotors , loaded calipers, bearings and duel master cyl form CarQuest. Works Great!
Glen Henderson
Freedom is not Free
Letohatchee, AL |
| | | | Supreme Being
Group: Forum Members Last Login: Tuesday, July 29, 2008 7:16 AM Posts: 287, Visits: 511 |
| | Ive read that disc brakes require higher brake fluid pressure than drum brakes. If you look at factory disc brake setups, they are usually power brakes. Ive read that installing power brakes is recommended when changing from drum brakes to disc brakes. |
