Junior Member
Last Login: Tuesday, December 22, 2009 5:55 AM
Visits: 232
I would like to put 1966 Galaxie steering wheel on my 56 Ford Vic. Will this fit? I sure hope so!
Supreme Being
Last Login: Friday, October 09, 2009 10:42 AM
Visits: 3,006
| John. The best way is to try it but make sure that the wheels are about the same Dia. unless the car has power steering. T M
in Bethel ,Vermont (aka: Bluedot Kid)1962-68 45th ENG. (DT) School of Hard Knocks C l a s s of 1960
Supreme Being
Last Login: Today @ 2:44 PM
Visits: 6,860
| John: The wheel will probably fit the splines, I put a '71 Bird wheel on my '57. However the horn circuit will be different, the '56 has a wire through the hollow steering shaft, the '66 will have a horn brush arrangement in conjunction with the turn signal switch. The turn signal cancelling cam arrangement is probably different also. John
