Harmonic Balancer repair?
Y-BlocksForever Forum
Harmonic Balancer repair? Expand / Collapse
Posted Friday, November 17, 2006 9:01 AM
Supreme Being
Last Login: Today @ 8:12 AM
Posts: 753, Visits: 6,226
Have any of you repaired the Balancer on a t bird. The sheaves are fine on mine but it needs to have a sleeve installed I guess or turned smooth. I know the sleeve can be purchased from places like Cassco. so I guess it just needs to be pressed on? any advice would be appreciated.
Alan Frakes ~ Tulsa, OK
Post #1323
Posted Friday, November 17, 2006 11:15 AM
Supreme Being
Last Login: Thursday, January 26, 2012 6:19 AM
Posts: 389, Visits: 1,178
Hi; On the 302 Fords I have done you just use acetone or laquer thinner on crank snout where the seal rides on the damper , then glue the sleeve on. No press required. This is not a load bearing area. Hope this helps. Pete
Post #1325
Posted Friday, November 17, 2006 7:12 PM
Supreme Being
Last Login: 2 days ago @ 8:07 PM
Posts: 1,237, Visits: 2,360
Put the balancer in the freezer overnight. Take out and immedialtely try to put the sleeve on. I've done a couple of things like this and it has worked. Never tried a balancer.
54 Victoria 312; 27T 255 Flathead, 48 Ford Conv 302, 56 Bird
Post #1327
Posted Friday, November 17, 2006 9:46 PM
Supreme Being
Last Login: Today @ 10:05 AM
Posts: 2,555, Visits: 6,850
Al:
Yes, I've done it on my Bird.  I got the sleeve at my local bearing store.  All they need is the diameter of the balancer where the sleeve goes.  Comes with an installer sleeve and instructions.  Also, the small block Ford damper is the same size, and local parts stores list those.  They probably don't list the Y Block.
John
Post #1331
Posted Saturday, November 18, 2006 10:54 AM
Supreme Being
Last Login: Wednesday, February 01, 2012 5:56 PM
Posts: 1,165, Visits: 4,936
Al - great numbers on your dyno run - thanks for publishing them earlier. Makes me think there's light at the  end of the tunnel.
I got the damper sleeve kit for my bird at NAPA - carried it in the door already marked with a size and they re-measured it anyway (sure to get a guy's nose out of joint). But they had the right one the next morning and now I've pitched the box.
Without a handy press at the house, I used the rack drive on my drill press for a smooth push to seat it. Like John mentioned, the kit was equipped with everything needed to push the sleeve squarely in place.
I think it would be worth putting it on a rebuild - even if the damper looked fairly good. The increase in diameter increases the preload on the seal lip and the material they use to make the sleeve is a harder, maybe slicker surface than the damper OD.
Post #1334
Posted Saturday, November 18, 2006 12:50 PM
Supreme Being
Last Login: Today @ 8:22 AM
Posts: 318, Visits: 1,075
Hello- When I realized the Duck's balancer had a groove wore into it where the seal lip rested, I filled the groove in with a brazing rod and then had our local machine shop turn it down to the correct dimension on their lathe- I always take the long way around problems, it seems...
BOO- YA!!!
Post #1335
« Prev Topic | Next Topic »
All times are GMT -6:00, Time now is 10:10am
Execution: 0.344. 13 queries. Compression Disabled.
