| | | Supreme Being
Group: Forum Members Last Login: Today @ 9:09 AM Posts: 114, Visits: 638 |
| | Y-Guys I need advice, on clutch selection for a perf 292 F-100. Diaphram? Long style, ???? Truck will go to the strip every now and then, but mostly street use. Thx Bill
BillPelham,Al |
| | | | Supreme Being
Group: Forum Members Last Login: Today @ 11:46 AM Posts: 496, Visits: 6,425 |
| | Bill, If you still have the 1 3/8 10 spline, you are out of luck for any off the shelf performance clutch. In fact, for some reason a stock clutch seems hard to find. I finally found a stock replacement at Carolina Clutch. It seems to be doing well with my moderately modified 292. If you've swapped to a different transmission you may be in luck.
Norcross, GA |
| | | | Supreme Being
Group: Forum Members Last Login: Yesterday @ 9:30 PM Posts: 778, Visits: 1,475 |
| | Bill, I was able to find a diapragm and kevlar disc at South Bend Clutch in South Bend, In. I've also dealt with Fort Wayne Clutch and they're also very good. The diapragm is a little easier to use on the street and it still has enough gripping power to run 13's @ over 100 mph.
Frank/RebopBristol, In ( by Elkhart)  |
