Supreme Being
Last Login: Thursday, May 19, 2011 1:50 PM
Visits: 260
Did any y blocks come with a clutch fan 1 car i got has 1 on it
86 mustang 351clt250/500r hybrid 4'' over swinger scr porting v2 reeds Q-pipe West virgina
Supreme Being
Last Login: Wednesday, July 01, 2009 3:40 PM
Visits: 487
| I am not aware of any of them coming that way from the factory. My friend has a 53 F-100 with a '62 galaxie 272 Y-block. He recently put a clutch fan on his. I do not know how it is working out yet. I have not talked to him in a few weeks.
1956 Ford F-100, 272 Y-block V8, 3 speed transmission (column shift), and 3.73 rear gears (spicer 44) ---Mountain Home, AR
Supreme Being
Last Login: 2 days ago @ 6:27 AM
Visits: 5,598
Hey Itman; Put clutch fan assembly on my 55' Bird. Have had great luck, runs cooler even in 4th of July parade. Got it at Casco. Also you should use the aftermarket schroud. Hope this helps God Bless Eddie
EddieLake Forest, Ca. 92630
Supreme Being
Last Login: Wednesday, May 09, 2012 5:17 PM
Visits: 666
Eddie Paskey (10/21/2008) Hey Itman; Put clutch fan assembly on my 55' Bird. Have had great luck, runs cooler even in 4th of July parade. Got it at Casco. Also you should use the aftermarket schroud. Hope this helps God Bless Eddie
Where do you find an aftermarket shroud? And where did you find a clutch fan? What was it off of?
E.J. in Havana FL
Supreme Being
Visits: 5,598
Fan Clutch and Fan came from Casco, you might also consider the small water pump pulley from Consours. My car runs at about 180 to 190 even on hot days and in parades, (4th of July). Hope this helps. God Bless Eddie
Supreme Being
Visits: 5,598
Forgot to tell you that Casco has the schrouds too!!! Eddie
Junior Member
Last Login: Wednesday, May 27, 2009 3:09 AM
Visits: 27
As others have mentioned, for a clutch-type fan to work, a shroud is absolutely necessary. There are lots of fan clutches out there, and you gets what you pay for. If I remember correctly, Hayden makes a good heavy duty one, and you should have five to seven blades on the fan.
Johnny, 1956 F-350 Wrecker
Supreme Being
Last Login: Today @ 5:41 AM
Visits: 3,957
Has anyone ever studied the comparable parasitic loses of "clutch" vs. "flex" fans? No clutch to fail with a flex fan, and initial costs should be less?
6 VOLTS/POS. GRD. NW INDIANA
Junior Member
Visits: 27
Daniel,
The clutch fan, when operating properly, uses less HP overall than a flex fan.
The more noise you hear from a fan, the more gas it's using. I have done any parasitic study/testing, only relying on my 40-plus years in the radiator business, and reading tons of articles and newsletters.
The positive of a flex fan is initial cost savings, plus a quality one will not wear out. A clutch starts wearing the first time it ever spins.
