1st day on the strip - disappointing
Y-BlocksForever Forum
««12
1st day on the strip - disappointing Expand / Collapse
Posted Thursday, October 22, 2009 6:19 AM
Supreme Being
Last Login: Tuesday, February 01, 2011 1:32 PM
Posts: 173, Visits: 1,415
Thanks ted - If I purchase a complete 28 spine unit, will it need to be test fit / adjusted for my vehicle?  Or is it a bolt in because the ring and pinion and would be set / tested before I received it.
Is there a company that anyone has used and/or recommends for a complete aftermarket diff?
- John
John: Lake Forest, IL
Post #33530
Posted Thursday, October 22, 2009 9:16 AM
Supreme Being
Last Login: Yesterday @ 7:33 AM
Posts: 1,840, Visits: 2,878
John.
 You can try to find one on Ebay or Craig's list, Gears are available from Summit/jegs or a local Speed shop. There will be some one in the chicago area who can set it up for you. If not, we can work out something with a buddy of mine here in the South Bend/ Elkhart area of Northern Indiana.
Post #33533
Posted Thursday, October 22, 2009 9:38 AM
Supreme Being
Last Login: Monday, January 30, 2012 2:53 PM
Posts: 378, Visits: 776
FYI, I run a 3:55 Detroit locker and at 75 mph I am reving right at 3000 rpm on the highway. I am Running 225 R16 radials on the car.
So far my best time with a stock (mileage unknown) 292 / FMX combo has been 17:02 @ 87mph. I know I can hit the 16's with some tuning and some slicks as I have been told that I am spinning the tires off the line every time. Hopefully that gives you some insight as to where you should be.
Post #33534
Posted Thursday, October 22, 2009 12:45 PM
Supreme Being
Last Login: 2 days ago @ 8:46 PM
Posts: 1,935, Visits: 3,920
I bought a complete "Trac-Loc" with new 3.50:1 gears set up and ready to install for $350 + shipping three years ago on eBay, it was an easy swap and is working great to this day.  I bought it from a guy in IN, maybe someone Frank knows.
God Bless.
  Tim                           http://yblockguy.com/
338ci Y-Block FED "Elwood",   301ci Y-Block Unibody LSR "Jake"  312ci Y-Block '58 F-100
Post #33539
Posted Thursday, October 22, 2009 12:55 PM
Supreme Being
Thanks guys - I appreciate it.  I'd like to think I can get to high 15s.  (without building a new motor)  Maybe i'm dreaming...
Let me rephrase my previous post:  What is a reasonable cost for a swap...  I like the $350 that Tim mentioned.  I see them online everywhere from $1300 to $150.  Buying just new components seem to add up to approx. $600+
Post #33542
Posted Thursday, October 22, 2009 1:30 PM
Supreme Being
Last Login: Sunday, February 05, 2012 10:43 PM
Posts: 359, Visits: 1,365
When I had my truck it had a 3.73:1 axle and the engine was spinning too fast for my taste at today's highway speeds.  So it depends on how you are going to use the car.  If you intend mostly street/strip then 3.89 would be OK but driving on a longish trip would get on the nerves (at least on mine).  If you are planning on longer trips than I would say 3.50 would be a fairly good compromise although the word is compromise.
Who ever suggested checking the tire patch was on target because 2.6+sec  60' times indicate that you are quite slow at that point on the track.  A locking rear axle will help but you need to check tire pressures no matter what and play around until both wheels spin at low pressure.  One thing with radials, if you go too low with pressure they will only contact the pavement on the outsides edges of the tires.  You will see this as two stripes of black from one or both tires.  I run about 18 psi on my street tires with a Traction lok and I can get about 2.0-2.1 60' times, stickshift T bird.  So far DOT slicks didn't help that much maybe 1.9 -2.0.
There may be engine issues also but others are on them!
Doug T
Post #33544
Posted Thursday, October 22, 2009 8:33 PM
Supreme Being
NewPunkRKR (10/22/2009)
  I like the $350 that Tim mentioned. +
I hope you know I ment a complete third member (pumpkin) not the whole rearend.
God Bless.
Post #33549
Posted Friday, October 23, 2009 5:57 AM
Supreme Being
Yeah, that's what I'm looking for.  I've never had any problems with the axel, so I'm assuming all the other components are in good shape.  I looked online for diff. components and also complete 3rd members and it was typically around $700-800 for a rebuild unit.  I'd like to find something for much less.
Post #33558
Posted Tuesday, October 27, 2009 9:46 AM
Forum Newbie
Forum NewbieForum NewbieForum NewbieForum NewbieForum NewbieForum NewbieForum NewbieForum Newbie
Last Login: Wednesday, December 30, 2009 12:27 PM
Posts: 9, Visits: 63
John- You have probably checked this, but in case you have'nt, be sure the intake/carb spacer will allow your secondaries to open. The stock items won't allow throttle plates much bigger than stock to open. David C.
Post #33733
« Prev Topic | Next Topic »
««12
Forum Moderators: Ted, Hoosier Hurricane
All times are GMT -6:00, Time now is 1:32am
Execution: 0.203. 9 queries. Compression Disabled.
