Supreme Being
Last Login: Today @ 11:06 AM
Visits: 10,355
Supreme Being
Last Login: Today @ 6:56 AM
Visits: 5,256
I think so, as long as you have the spin on filter adapter, I see no reason that they wouldn't work. Ford had a right angle filter adapter, I think it was used on some H/D trucks.
Glen Henderson
Freedom is not Free
Letohatchee, AL
Supreme Being
Last Login: Today @ 7:25 AM
Visits: 7,284
| The remote setup requires a bypass adaptor for the block which attaches to your existing spinon adaptor, and the actual remote filter holder which is mounted wherever you choose. Quite a few suppliers have them. Speedway, AutoZone, and others. Mine is a Haynes that came from Autozone. Make sure the hoses going from the bypass to the oil filter recepticle are high pressure, hydraulic rated. Not run of the mill water heater hose. Speedway has the hose in either blue or black.  Mike
Mike, located in the Siskiyou mountains, Southern, OR292 powered 1946 Ford 1/2 ton
Supreme Being
Visits: 10,355
Supreme Being
Visits: 7,284
| http://www.speedwaymotors.com/p/1158,,_Remote-Bypass-Adapters.html?itemNo=REMOTE+OIL+FILTER This Speedway bypass #7201013 would work, or any bypass with the 3/4 "-16 thread. Many Ford motors use the same one. FYI the Haynes unit has two options on the same bypass for hose attachment. One with hoses running roughly parallel to block, and the other has the hoses going straight out from the block. You just plug the two that arent used. It gives a little more flexibility. Mike
Supreme Being
Last Login: Today @ 3:02 PM
Visits: 3,112
| chuck i have a 57 312 in the garage that has a Hildebrand remote filter adapter on it.it has two fittings one in the center and one on the outer edge.i didnt take it off to see what the inside looks like carl
Supreme Being
Last Login: Yesterday @ 8:45 PM
Visits: 501
If your into salvage parts, I pulled a nice remote filter cooler setup off of a 88 e350 460 econoline van. My wifes windstar 3.8 has one too. happy hunting, Mark
thanks, Mark
