Supreme Being
Last Login: Yesterday @ 11:40 AM
Visits: 1,122
| I didnt want to bug John just yet, but need to know the thickness of the adaptor plate he sells for affixing a T-5 tranny to a Y. If anybody knows the amount of rotation his new design offers that would be great too. I'm awaiting a gutted case and tail section so I can mock-up investigate frame and tunnel mods will be necessary before cut'n and weld'n. Thanks in advance for any replies. Cheers... Brian
Cylinder Index = 84Current Experiment = `57 Tbird, Grand Rapids, Michigan
Supreme Being
Last Login: Saturday, December 24, 2011 1:38 PM
Visits: 1,222
| Y-Guy Noob: I'll try to measure mine wednesday and get back to you. Bill
BillPelham,Al
Supreme Being
Visits: 1,222
| Y-Guy Noob Sorry it took so long to get the measurement, it's 3/4" thick give or take a 1/16". Bill
BillPelham,Al
Supreme Being
Visits: 1,122
| Cool beans, Bill... I have an empty T-5 case and tail coming next week for mock-up and now I can make some temp spacers (+/- 1/16", lol) to see whats what. I may still have to bug John, cuz I understand the new plates have a clockwise rotation to postion the shifter closer to the driver. Thanks again, Bill for the measure. Cheers... Brian
Supreme Being
Last Login: Tuesday, January 31, 2012 5:26 AM
Visits: 2,390
It has been several years but recall the thickness being .750" and therefore did not need to shorten the input shaft.
You gotta have the right tools and know how to use 'em.TC - Austin, Texas
Supreme Being
Visits: 1,122
Ok fellas... noob here... which is it, 3/4" OR .750 ???? Geesh... now I'm gonna have to make two different spacer sets...
Supreme Being
Visits: 1,222
| Y-Guy Noob: 18.? mm................... Bill
BillPelham,Al
Forum Guru
Last Login: Tuesday, March 29, 2011 4:48 PM
Visits: 211
.750 is the same as 3/4 of an inch
Supreme Being
Last Login: Today @ 10:05 AM
Visits: 6,850
| Bill: I come up with 19.05 mm, but that is a moot point because Ys are built to fractional sizes, so the related parts should be fractional also. Just had to pull your chain a little, lol.
Supreme Being
Last Login: Monday, January 30, 2012 9:19 PM
Visits: 767
| The adapter is 3/4" .750" or 19.05mm thick,depends on the mood we're in that day. The original adapters were not rotated because the bottom 2 bolt holes actually line up with the 49-64 bellhousing. This made mounting the transmission easy but the rear mount was rotated making the crossmember a pain. The rotated version moves the shifter closer and makes the rear mount easier but makes mounting the adapter to the bellhousing a little more involved. The pilot portion of input shaft must be shortened 1/4" so it doesn't bottom in the back of crankshaft. If the adapter is made thick enough so that the input shaft doesn't need to shortened you won't get full engagement of the splines.
