Supreme Being
Last Login: Saturday, December 17, 2011 12:23 PM
Visits: 328
I was thinking about converting to four wheel drive on my 57 f100.I have a mild 292 and c4 transmission.Does anybody know if I can still use the c4 for a four wheel drive transfer case?Did any of the later model 4x4s with Ys come with automatics?
55 fairlane gasser 312 /c4, 57 f100 292/c4, 52 mainline gasser 302/t10 4speed
Supreme Being
Last Login: Wednesday, November 16, 2011 6:22 PM
Visits: 763
Ford used C-4's in Broncos and light trucks with four wheel drive so you could used the transfer case from them. You would also have to install a shorter output shaft and tail housing for the transfer case. I once put a complete Bronco four wheel drive under a '72 Ford E-100 van. Lotsa fun...
BOB
Supreme Being
Last Login: 2 days ago @ 8:46 PM
Visits: 8,008
Supreme Being
Last Login: Sunday, May 08, 2011 8:41 AM
Visits: 2,157
Supreme Being
Last Login: Thursday, November 24, 2011 5:49 PM
Visits: 916
Nathan
Where about are you? Here is an add for you if you are close...best offer...for sale a while
1960 Ford F100 4X4 for sale
john duchart (duchart27@yahoo.ca)
YOU CAN ALSO CALL him AT 519 630 5749
Cheers
Gordie T Long Point, Ontario
Supreme Being
Visits: 328
Hey,Im out in southern cal.Ive been able to locate a c4 and 205 transfer case along with a dana 60 with disk brakes.I think they came out of a 70s 4x4?Im goin to rebuild everything and fab up the necessary mounts and such.Ill be useing coil overs and four bar suspension.My 292 has plenty of power for the job.Ill put updates up as I go,thanks for all the input.
