Converting '62 Unibody I-6 to 292
Y-BlocksForever Forum
«««123
Converting '62 Unibody I-6 to 292 Expand / Collapse
Posted Monday, February 08, 2010 4:41 AM
Forum Guru
Forum GuruForum GuruForum GuruForum GuruForum GuruForum GuruForum GuruForum Guru
Last Login: Sunday, February 27, 2011 7:19 AM
Posts: 72, Visits: 181
Before you start ditching parts take a good look. You mentioned swapping front end pieces. The 62 upper valance is different than 64. It's an easy fix though, the F O R D is spaced differently. I like the 64 valance better so it's what I used.
The Y block mount is pretty easy to weld on the front crossmember - just line it up with the 223's mounting hole. Pretty easy to remove from your 64 too, just cut through the welds on the top & sides and give it wack with a 5 lb hammer - comes right off, lol. I went through the same thing with my truck, but both ways - it was a 292 truck, I had a 223. I had to cut the mount out to drop the 6 in, then when I got a 292 I had to weld it back in place.
64 valance on a 62 Uni.
1964 F 100 LWB Roller 5.0 & T-5
2001 Jeep Cherokee XJ
2009 Harley FXSTB Night Train
"I still have a Y block - it's just not in anything yet."
Post #39332
Posted Monday, February 08, 2010 9:27 AM
Supreme Being
Last Login: Yesterday @ 7:25 AM
Posts: 1,078, Visits: 7,284
Greg, you have a very nice unibody!  It looks like your headlight rings/trim are '64?
I am going to use the '64 front valance with the 62 grille.  I like the 62 grille better.
Mike, located in the Siskiyou mountains, Southern, OR
292 powered 1946 Ford 1/2 ton
Post #39345
Posted Monday, February 08, 2010 6:39 PM
Forum Guru
Those headlight rings came off a 62 parts truck with the grill. All Slick headlight rings are the same as far as I have ever seen - only difference is chrome steel - 61, or painted steel & aluminum.
My Uni is in the garage right now, total redo of the body, filled seams, shaved drip rail and new paint - same style. Working on the roof now.
Post #39389
« Prev Topic | Next Topic »
«««123
Forum Moderators: Ted, Hoosier Hurricane
All times are GMT -6:00, Time now is 12:46pm
Execution: 0.109. 8 queries. Compression Disabled.
