Weld a bell housing?
Y-BlocksForever Forum
12»»
Weld a bell housing? Expand / Collapse
Posted Saturday, January 23, 2010 11:39 AM
Forum Member
Forum MemberForum MemberForum MemberForum MemberForum MemberForum MemberForum MemberForum Member
Last Login: Saturday, March 05, 2011 5:34 AM
Posts: 25, Visits: 90
Is it possible to weld a  bell housing? Are these things cast iron?  If so, tig, mig, rod type.  It appears my OG bell was smashed.  It was brazed back together.  Over 20 pieces, no kidding!!
Post #38289
Posted Saturday, January 23, 2010 5:28 PM
Forum Member
Last Login: Tuesday, December 20, 2011 8:06 PM
Posts: 37, Visits: 78
I really can't see why anyone would weld 20 pieces back together, unless they couldn't find another housing. That would be funny to see. But yes the bells are made of cast and cast can be brazed. You have to heat the whole thing like in a bon fire and weld it when it is still very hot. Sometimes poor people have poor ways. But where there is a will there is a way.
Post #38305
Posted Saturday, January 23, 2010 9:12 PM
Supreme Being
Last Login: Today @ 10:15 AM
Posts: 450, Visits: 8,025
CodyConley (1/23/2010)
Is it possible to weld a bell housing?Are these things cast iron? If so, tig, mig, rod type. It appears my OG bell was smashed. It was brazed back together. Over 20 pieces, no kidding!!
When I tore my truck down in '97, I found out my bellhousing had been welded. I think it was at one of the mounts. I had owned the truck 21 years at that point and never knew it. I bought another bellhousing at carlisle and scrapped the other one.
  Dennis in Lititz PA
Post #38318
Posted Sunday, January 24, 2010 4:51 PM
Supreme Being
Last Login: Today @ 4:53 AM
Posts: 326, Visits: 1,892
It is possible to weld or braze cast iron.
They all involve preheating the item on a well insulated surface - I have always found clay house or paving bricks to be the best.
You need to heat the part to be welded slowly and evenly and allow it to cool slowly - don't douse it with water when you finish or the metal will crack.
Brazing with an oxy/acetylene torch works well and is what most people use, but for items subjected to vibration (such as bell housings) arc welding with special rods for cast iron will give a result as strong as the original.
The way I was taught to gauge the heat to achieve was to spit on the part as you are heating it.
The correct temperature is when the spit boils immediately and will stay on the surface. It almost jumps off the surface when it is the right temperature. You can heat it more than this but you are just wasting gas. It's a bit hard to explain but when you see it happen you know it is right.
The limiting factor is how big your heating torch is - it is much better to use the multi-burner types.
You need to heat cast iron to this correct temperature and allow to cool slowly to avoid the metal cracking around the weld. It will always crack if it is not hot enough or it is cooled too quickly.
I have never had a problem welding in this manner.
Hope this answers your question.
Rick - West Australia
Post #38374
Posted Sunday, January 24, 2010 4:58 PM
Supreme Being
I probably should have mentioned in my earlier reply that you need to heat the whole part you are welding evenly. This then means that a bell housing will take a bit of gas and heat before you can start to weld it. It is for this reason that the multi-burner nozzles are better.
They were designed with this use in mind.
A large oxy welding tip will heat cast iron but its heat is more intense and centered around the tip.
It will take a lot longer to heat up a large project such as a bellhousing with the smaller tips.
Sorry my posts were a bit longwinded.
Regards
Post #38375
Posted Saturday, January 30, 2010 5:42 PM
Forum Newbie
Forum NewbieForum NewbieForum NewbieForum NewbieForum NewbieForum NewbieForum NewbieForum Newbie
Last Login: Sunday, February 07, 2010 8:33 PM
Posts: 9, Visits: 72
Probably going to ruffle some feathers with this one, but you can stick weld cast iron with a nickel rod without preheating in short beads allowing the weld to throughly cool
and peening while cooling. Slow but always works for me
Post #38809
Posted Saturday, January 30, 2010 6:14 PM
Supreme Being
Last Login: Yesterday @ 9:23 PM
Posts: 1,935, Visits: 3,916
Pre-heat and wire feed, that's what I do when modifying for the T-5, but if it is a matter of a shattered bell get another they aren't that hard to come by.
God Bless.
  Tim                           http://yblockguy.com/
338ci Y-Block FED "Elwood",   301ci Y-Block Unibody LSR "Jake"  312ci Y-Block '58 F-100
Post #38812
Posted Saturday, January 30, 2010 10:03 PM
Supreme Being
Last Login: 2 days ago @ 12:35 PM
Posts: 1,255, Visits: 4,934
mctim64 (1/30/2010)
Tim, my thoughts exactly! couldnt see how there would be a shortage of these in the US. Why would anyone want to use something that is a definite liability!!. regards bill.
 Down Under, Australia
Post #38820
Posted Sunday, January 31, 2010 7:55 AM
Co-AdministratorCo-AdministratorCo-AdministratorCo-AdministratorCo-AdministratorCo-AdministratorCo-AdministratorCo-Administrator
Last Login: Yesterday @ 5:43 PM
Posts: 3,130, Visits: 2,148
badnewsdan (1/30/2010)
Probably going to ruffle some feathers with this one, but you can stick weld cast iron with a nickel rod without preheating in short beads allowing the weld to throughly cool and peening while cooling.
Dan.  No ruffled feathers on my end for using a stick welder to weld cast iron.  That’s my own preferred method for cast iron welding although I’m also considered pretty fair at both MIG and TIG welding.  While the Y was at the EMC challenge, several students commented on the welding on the mounts and the accelerator linkage as they thought it was an unusual weld pattern for a wire feed.  They were surprised when I told them it was stick welded as that particular style of welding was not being tought as part of their curriculum at UNOH.
Lorena, Texas  (South of Waco)
Post #38833
Posted Sunday, January 31, 2010 8:38 AM
Supreme Being
Last Login: Today @ 7:26 AM
Posts: 720, Visits: 4,570
No ruffled feathers here either.I've been stick welding cast iron for 50 years.It's only been the last few years that people started saying you can't do that.
Paul,
Boonville,MO
Post #38837
« Prev Topic | Next Topic »
12»»
All times are GMT -6:00, Time now is 10:15am
Execution: 0.172. 9 queries. Compression Disabled.
