256 Mercury cams
Y-BlocksForever Forum
256 Mercury cams Expand / Collapse
Posted Wednesday, February 03, 2010 11:31 AM
Forum Member
Forum MemberForum MemberForum MemberForum MemberForum MemberForum MemberForum MemberForum Member
Last Login: Today @ 9:43 AM
Posts: 46, Visits: 1,288
have a 256 mercury motor going to fit 272 crankshaft & rods will the 272 camshaft fit also.
    RAY. Y,S ALWAYS
Post #39038
Posted Wednesday, February 03, 2010 11:37 AM
Supreme Being
Last Login: Tuesday, December 20, 2011 11:49 AM
Posts: 307, Visits: 1,082
I have been told they will, don't forget to change the dizzy also.
Ol'ford nut
Central Iowa
56 Vic w/292 & 4 spd.
Post #39040
Posted Thursday, February 04, 2010 7:24 AM
Co-AdministratorCo-AdministratorCo-AdministratorCo-AdministratorCo-AdministratorCo-AdministratorCo-AdministratorCo-Administrator
Last Login: Yesterday @ 5:43 PM
Posts: 3,130, Visits: 2,148
The crankshaft will fit right in so no problem there.  But the cam is another story.  If  the 256 engine is a '54 model, then the cam journals may be the larger size which prevents the ’55 and up camshafts from being run without modifying the cam bearings appropriately.  The ’54 engines had cam journal sizes and corresponding cam bores in the block that were approximately 0.125” larger than the ’55 and up engines.  It's easy enough to make new cam bearings for the early block though and use the later camshafts if you have access to a capable machine shop.  The '55 model pickup 256 engines had the smaller cam journals so no problems there in using any of the later cams.
Lorena, Texas  (South of Waco)
Post #39103
Posted Sunday, February 07, 2010 1:48 AM
Forum Member
thanks for that information ted told the machine shop where i,m having the engine rebuilt ,and he said if the cam bearings couldn,d be found that they would machine new ones up.are going to use the heads of a 272 also.
    RAY. Y,S ALWAYS
Post #39291
« Prev Topic | Next Topic »
All times are GMT -6:00, Time now is 10:38am
Execution: 0.219. 9 queries. Compression Disabled.
