Speedo gear
Y-BlocksForever Forum
Speedo gear Expand / Collapse
Posted Friday, February 05, 2010 9:41 AM
Supreme Being
Last Login: Tuesday, December 20, 2011 11:49 AM
Posts: 307, Visits: 1,082
I have a 4 speed behind my 292 that is out of a 62 or 63. I bought a speedo cable (56 won't work) but need idea of what gear to put on it. Not sure of rear gear. Car was originally auto but was converted to stick before I bought it.
Ol'ford nut
Central Iowa
56 Vic w/292 & 4 spd.
Post #39198
Posted Friday, February 05, 2010 4:46 PM
Supreme Being
Last Login: Today @ 10:05 AM
Posts: 2,555, Visits: 6,850
Ol Ford nut:
Determine what the rear axle ratio is.  Then buy a gear for a '62 with that, or at least close to, ratio.  Should get you in the ballpark.  You can vary the tooth count up or down if the first choice isn't satisfactory.
Post #39211
Posted Friday, February 05, 2010 6:49 PM
Supreme Being
Last Login: 2 days ago @ 8:07 PM
Posts: 1,237, Visits: 2,360
One of the problems with speedo gears is that ford used gears that had "teeth" that ran different directions. One determination may be on what side of the trans the gear was located on.
54 Victoria 312; 27T 255 Flathead, 48 Ford Conv 302, 56 Bird
Post #39223
Posted Saturday, February 06, 2010 5:36 AM
Supreme Being
Ol Ford nut:
Be sure to get the clip that holds the gear onto the cable stub, or you will end up with the gear in the bottom of the trans.
Post #39243
Posted Saturday, February 06, 2010 1:10 PM
Supreme Being
Last Login: 2 days ago @ 12:35 PM
Posts: 1,255, Visits: 4,934
Hoosier Hurricane (2/6/2010)
Ol Ford nut:
John, i found out about the clip the hard way, i made a clip from a loop from accelerator spring, it is still working! regards bill.
 Down Under, Australia
Post #39258
« Prev Topic | Next Topic »
All times are GMT -6:00, Time now is 10:41am
Execution: 0.125. 7 queries. Compression Disabled.
