Supreme Being
Last Login: Thursday, December 22, 2011 10:28 PM
Visits: 1,820
I have four Y block aluminum manifolds; 1 Edelbrock 573, 1 Edelbrock 553, 1 Offy 3x2, and 1 Marine manifold. The Offy and the Marine intakes are painted. I want to restore them; remove the paint, media blast, and possibly polish a couple of them. I tend to like the natural finish of the aluminum but also like the polished look. I will probably use the 573, the original cast finned Tbird valve covers, and I bought a Mummert valley pan and aluminum intake hold downs for my Tbird. The others I will probably use to trade/sell for other stuff. How well does the polish surface hold up under moderate driving use? I was thinking of using Eastwood's polishing kit. Any opinions, suggestions or advice would help.
Thanks,
Mark Hebard
57 Black Tbird 312/auto
65 Galaxie 500 2drhdtp 352/Cruiso
66 F100 Custom Cab ShortyStyleside 390/C6
Monterey Bay, California
Supreme Being
Last Login: Today @ 3:59 AM
Visits: 1,097
| Mark; I polished an Edelbrock 257 dual quad intake and I can tell you it takes a long time and is alot of work. Not to say the end result isn't worth it! The Eastwood polishing kit is a good kit, but it is really for the final stages of polishing. The big problems I found in polishing these intakes is that the castings are rough with alot of angles and tight areas and the manifolds themselves have alot of surface area. I started out hand polishing the intake with#400 emery. You can try using power tools in this stage such as an angle die grinder, dremmel, etc, with emery cones, cross buffs, flapper wheels, etc, but you run the risk of cutting into the aluminum too fast. I then went to #600 emery and then #800 emery, all by hand before I even started using buffing cones and other buffs from the Eastwood kit. After I got the shine I wanted, I sealed the aluminum with Zoops Seal. Eastwood also sells a clear spray sealer which I bought but haven't used yet. So, my advice would be, have at it, take your time and be patient. I did mine as a winter project. I brought it in the house, sat in front of the fireplace at night, and polished as I watched the tube. GOOD LUCK! Rono
 Ron Lane Newport, ME
Supreme Being
Last Login: Yesterday @ 9:17 PM
Visits: 10,356
Supreme Being
Last Login: Yesterday @ 5:02 PM
Visits: 6,228
I have to agree I would never set out to polish one. They look good BUT wow-zee the time! And money if you have it done.
Actually my favorite is to have them blasted, either soda, pecan hulls or carbide and such. Makes a nice clean aluminum finish.
Moonshadow has a good alternative method that i see a lot of the time as well. It will keep you from having to re-polish.
And I also am a fan of painting them. They still look cool with the carbs linkage and chrome standing out more, But then I'm a rebel-I painted my Blue Thunder intake FORD red!
Alan Frakes ~ Tulsa, OK
Supreme Being
Visits: 10,356
Forum Guru
Last Login: Today @ 10:22 AM
Visits: 604
I have polished an Edelbrock 2 x 4 manifold and then had it chrome plated and 20 years later it still looks good as well as polishing and chroming the timing cover. I did it all with a die grinder and then polished them with rouge and a polishing pad on an old motor. I do plug off the crossover in the manifold with a piece of sheet metal between the manifold and the heads. I would trade a chromed Bird timing cover for an aluminum one if you have one or anyone else out there. It looks just like a polished aluminum one but never needs polishing.
Vic Correnti
Supreme Being
Visits: 10,356
Supreme Being
Visits: 1,820
I am sitting here looking at the Edelbrock on my desk. It is intimidating to say the least. Time to take some of the good advice here and do some snooping on Google. The aluminum valley pan and intake hold downs I ordered from Mummert showed up today. Maybe that would be a place for a beginner to start. Nice and flat.
Mark Hebard
