Supreme Being
Last Login: Wednesday, March 30, 2011 1:40 PM
Visits: 594
| Will a NP 435 4 speed truck trans bolt up to a 63 truck bell?
Supreme Being
Visits: 594
| A little help here fellas.
Forum Guru
Last Login: Today @ 8:14 AM
Visits: 1,013
| Didn't post before because I'm not familiar w/ the 435,,,the large truck bells have two bolt patterns,,,,,older NP's shift rails interfere w/ the bell. When I got my 600 the bell had been torched for clearance,,,it had cracked & had to replace it. now have a Clark OD 5 speed.
Supreme Being
Visits: 594
| Glanced at the t-98 bolt layout while under the black rat today, & noticed that the NP 435 that I picked up has the 4 bolts in a alomost the same layout on each side. The t-98 has two that are close together top to bottom on the passenger side. Looks almost like the bell would need the same mods as it would for a t-5. Hardly worth it, as I would rather have the t-5 if I am going to mod the bell. Can anyone specify if there are multiple truck bells with different bolt patters? This pic from John's site is of a different bell than the one I have in the truck. I have a second one laying around that I need to verify if it is like the one pictured here or if it is like the one currently on the f-250 black rat.
Btw, here's some pics of the trucks in the garage. Thank god for wheel dollys, which allow me to roll the rear of the stake bed withing a 1/4" of the wall to make more room to park the second truck and still do small jobs!
Supreme Being
Last Login: Today @ 6:12 AM
Visits: 27,689
There are at least two different patterns for the trucks.
Supreme Being
Last Login: Monday, January 30, 2012 9:19 PM
Visits: 767
| From what I've been told, the New Process was an option in 1964 (maybe 63 also). It requires a special bellhousing. The bellhousing in the picture you posted is for a 3-speed truck. The T-98 4-speed used a different bell. The NP is another style.
Supreme Being
Visits: 594
| Thanks John. Looks as though unless I luck onto the bell of an optioned truck I will stay with the t-98 if the donar diffs agree gearing wise.
