Supreme Being
Last Login: Friday, January 27, 2012 11:21 AM
Visits: 614
Does anyone know the center to center rod lenghts of the 292 and the 312?
I've read in other post you can actually use the 292 rod with the 312 crank if you grind down the piston. But, in order to figure out the appropriate piston compression hieght and piston clearance I need to know the different connecting rod heights.
Thanks, the dawg
Heber City, UT (15 mins outside of Park City- basically it's in the mountains)
55 Effie
Supreme Being
Last Login: 2 days ago @ 12:35 PM
Visits: 4,934
| 312 rod length; 6.250". 292 rod length; 6.320"
