Supreme Being
Last Login: Sunday, May 08, 2011 8:41 AM
Visits: 2,157
Supreme Being
Last Login: Yesterday @ 6:52 PM
Visits: 2,365
Those are for a tube that supplies heat to the automatic choke. An "L" fitting goes into the passenger side which holds a tube going to the automatic choke. The other side has a little round thing (57). For 56, there was a tube going up into the carb to heat it. Not sure what 55 had.
New tubes are available from the parts suppliers as well as the L fitting and the round thing. Usually are rusted from the exhaust and have to be drilled out.
54 Victoria 312; 27T 255 Flathead, 48 Ford Conv 302, 56 Bird
Supreme Being
Last Login: Yesterday @ 6:56 PM
Visits: 804
The HD 292 which could be optioned on the bigger trucks came with manual chokes so there was never a hole drilled for the choke tube.
1959 and 1960 f-100sAkron OH
Supreme Being
Visits: 2,157
Supreme Being
Last Login: Yesterday @ 8:25 PM
Visits: 8,018
Supreme Being
Visits: 2,365
bloodyknucklehill (2/21/2010) so if i'm using a carb without an automatic choke then these would be unecessary right?
The only problem is if the tube is corroded inside the intake. If it is, then you will have exhaust coming out of the holes as far as I know as the pipe runs in the exhaust crossover.
