Brake Fluid
Y-BlocksForever Forum
Brake Fluid Expand / Collapse
Posted Friday, February 26, 2010 12:54 PM
Forum Newbie
Forum NewbieForum NewbieForum NewbieForum NewbieForum NewbieForum NewbieForum NewbieForum Newbie
Last Login: Monday, March 07, 2011 10:14 PM
Posts: 6, Visits: 24
I want to remove all the old brake fluid in my 55 crown.  I have a MityVac pump kit and have purchased Valvoline Synthetic Dot 3&4.  Does anyone have any suggestions.  Thanks JDH
JDH
Post #40278
Posted Friday, February 26, 2010 6:19 PM
Supreme Being
Last Login: Yesterday @ 6:52 PM
Posts: 1,240, Visits: 2,365
Assuming that DOT 3 or 4 was in the car to begin with, just make sure the lines are not rusted, flattened or crimped. If you get any rust in the old fluid, be sure to clean completly. Also, if the flex lines are old, replace them. You can't see internal damage on these flex lines
54 Victoria 312; 27T 255 Flathead, 48 Ford Conv 302, 56 Bird
Post #40294
Posted Saturday, February 27, 2010 6:57 AM
Co-AdministratorCo-AdministratorCo-AdministratorCo-AdministratorCo-AdministratorCo-AdministratorCo-AdministratorCo-Administrator
Last Login: Today @ 5:30 AM
Posts: 3,132, Visits: 2,149
I’ve used alcohol in those instances where I needed to clean the brake line passages in lieu of replacing with new lines.  If doing this or any other type of line cleaning, just be sure to air blow the lines suffieciently before closing everything up and replacing the fluid.
Lorena, Texas  (South of Waco)
Post #40309
Posted Saturday, February 27, 2010 10:30 AM
Supreme Being
Last Login: Today @ 10:19 AM
Posts: 2,557, Visits: 6,863
Since the lines and bleeder screws all are at the top of the cylinders, the only sure way to get ALL the old fluid out is to take the wheel cylinders apart and clean them after flushing the lines as Ted mentioned above.
Post #40317
Posted Saturday, February 27, 2010 1:34 PM
Forum Newbie
Hey, thanks for the help.  I never thought about the covered lines being rusted.  Next job is replacing them.  I like the idea of alcohol flushing plus the disassembly of the wheel cylinders. Should I do anything with the master cylinder other than sucking the fluid out, maybe running alcohol through it or is that too radical.  John
JDH
Post #40325
Posted Saturday, February 27, 2010 1:39 PM
Forum Newbie
Hey I forgot.  This car was redone about 1985 so it probably has dot 3.  When I pulled the drums everything looks like it came from the factory.  Its nice and clean.   John
JDH
Post #40326
« Prev Topic | Next Topic »
All times are GMT -6:00, Time now is 12:31pm
Execution: 0.156. 6 queries. Compression Disabled.
