Intake Manifold discolored
Y-BlocksForever Forum
Intake Manifold discolored Expand / Collapse
Posted Monday, March 01, 2010 9:06 AM
Forum Newbie
Forum NewbieForum NewbieForum NewbieForum NewbieForum NewbieForum NewbieForum NewbieForum Newbie
Last Login: Saturday, August 06, 2011 8:26 AM
Posts: 3, Visits: 12
rebuilt motor, driven approx 100mi, the driver side manifold has begun to discolor only where the manifold ports extend to meet the head at just above the 6&7 cylinders. the red paint on the manifold has turned grey(seems like heat is the culprate). is this a sign of leak?
Post #40431
Posted Monday, March 01, 2010 10:07 AM
Supreme Being
Last Login: Wednesday, November 16, 2011 6:22 PM
Posts: 259, Visits: 763
Assume we are talking about the intake manifold as opposed to exhaust manifold?? Sounds like where the exhaust crossover in the intake, burning off the paint Common problem, no leak. Use the T-Bird/Truck intake gaskets with the restricted crossover or if you are in a warmer climate, plug it all together.
BOB
Post #40434
Posted Monday, March 01, 2010 12:04 PM
Supreme Being
Last Login: Today @ 10:36 AM
Posts: 1,092, Visits: 3,853
If you repaint that part of the manifold, try ultra high-temp engine paint and than apply correct color top coat. Does your vehicle have a thermo riser valve on the exhaust manifold? If it sticks closed, even a restricted intake gasket might still burn the paint (?).
6 VOLTS/POS. GRD. NW INDIANA
Post #40437
Posted Monday, March 01, 2010 8:48 PM
Supreme Being
Last Login: Yesterday @ 6:52 PM
Posts: 1,240, Visits: 2,365
You will never stop it from doing that until you get the small exhaust port gaskets or close them off altogether. Even with the small exhaust port gaskets it will eventually burn, just takes longer.
54 Victoria 312; 27T 255 Flathead, 48 Ford Conv 302, 56 Bird
Post #40466
Posted Monday, March 01, 2010 10:33 PM
Forum Newbie
thanks for the heads-up. i dont mind the discoloration. looking around for these gaskets, i came across http://www.headersbyed.com/__ford.htm#Y block. recommend these are better compared to http://www.summitracing.com/search/Department/Gaskets-Seals/?keyword=y+block+header found ?
Post #40469
Posted Monday, March 01, 2010 10:34 PM
Forum Newbie
nope,no thermo riser
Post #40470
Posted Tuesday, March 02, 2010 6:27 AM
Forum Newbie
Last Login: Monday, July 11, 2011 9:50 AM
Posts: 8, Visits: 40
I bought some gaskets with a metal plate on ebay from http://stores.ebay.com/Rons-Classic-Car-Gaskets. Thet have about a 1/2" hole in the center.
I would rather block mine off completely as I have a boat.  How exactly is the best way to do that? Do I take a piece of flat metal and place it over the hole, or use the regular gaskets and a larger piece of metal?
Post #40477
Posted Tuesday, March 02, 2010 6:58 AM
Co-AdministratorCo-AdministratorCo-AdministratorCo-AdministratorCo-AdministratorCo-AdministratorCo-AdministratorCo-Administrator
Last Login: Today @ 5:30 AM
Posts: 3,132, Visits: 2,149
Riley (3/2/2010)
I bought some gaskets with a metal plate on ebay from http://stores.ebay.com/Rons-Classic-Car-Gaskets. They have about a 1/2" hole in the center.  ......I would rather block mine off completely as I have a boat.  How exactly is the best way to do that?  Do I take a piece of flat metal and place it over the hole, or use the regular gaskets and a larger piece of metal?
Two small pieces of shim stock about 0.015”-0.020” thick placed over the intake gasket heat riser holes before installing the intake manifold will block the heat riser portion of the intake.  If the intake gasket you are using already has metal stock with a hole in it at the heat riser location, simply remove that piece of metal and lay your substitute metal pieces over the existing gasket hole.  I like to put a 1/8” 90° bend at the tops of the new block off metal pieces which allows the plates to sit in place while the intake is being positioned prior to bolting it down.
Lorena, Texas  (South of Waco)
Post #40480
Posted Tuesday, March 02, 2010 8:43 AM
Supreme Being
63pikup (3/1/2010)
thanks for the heads-up. i dont mind the discoloration. looking around for these gaskets, i came across http://www.headersbyed.com/__ford.htm#Y block. recommend these are better compared to http://www.summitracing.com/search/Department/Gaskets-Seals/?keyword=y+block+headerfound ?
63pikup, It appears that the gaskets you have listed are exhaust gaskets. You want the intake gaskets with the restriction...
BOB
Post #40491
Posted Tuesday, March 02, 2010 11:23 AM
Forum Guru
Forum GuruForum GuruForum GuruForum GuruForum GuruForum GuruForum GuruForum Guru
Last Login: Yesterday @ 9:28 AM
Posts: 67, Visits: 1,015
For my truck, I milled a recess around that heater port and fitted a 3/32 piece of flat stock in to it with a 1/2 hole like the truck gasket.
Post #40496
« Prev Topic | Next Topic »
All times are GMT -6:00, Time now is 6:51pm
Execution: 0.109. 7 queries. Compression Disabled.
