Scrub mechanic????
Y-BlocksForever Forum
Scrub mechanic???? Expand / Collapse
Posted Monday, March 01, 2010 10:47 PM
Supreme Being
Last Login: Monday, January 23, 2012 9:09 PM
Posts: 140, Visits: 1,267
 A friend of mine was asked to tear apart this motor and find the noise.....I couldn't believe the thrust bearing would even fit on the front main!!!!!!  Barry L
Post #40473
Posted Tuesday, March 02, 2010 5:29 AM
Supreme Being
Last Login: Today @ 10:19 AM
Posts: 2,557, Visits: 6,863
Barry:
Were the main cap bolts also that loose, or did you loosen them?  I assume there is no thrust bearing in the #3 saddle.  That would no doubt cause a nose.  A thrust bearing in the front probably wouldn't hurt anything, there's room for it.
Post #40476
Posted Tuesday, March 02, 2010 7:52 AM
Supreme Being
Last Login: Today @ 6:53 AM
Posts: 1,936, Visits: 3,921
that's funny!   I don't know how many times I've seen scrub guys try to put the thrust on the #5 main in a 289/302 just because they are programmed that way but never on the #1.
God Bless.
  Tim                           http://yblockguy.com/
338ci Y-Block FED "Elwood",   301ci Y-Block Unibody LSR "Jake"  312ci Y-Block '58 F-100
Post #40486
Posted Tuesday, March 02, 2010 10:33 AM
Supreme Being
Last Login: Yesterday @ 9:17 PM
Posts: 1,959, Visits: 10,356
I'm sure the term "Scrub" is correct. But who said this guy was a "Mechanic"? Chuck in NH
Y's guys rule!Looking for McCullouch bracketts and parts.
Also looking for 28 Chrysler series 72 parts.
 MoonShadow, 292 w/McCulloch 28 Chrysler Roadster (Y in the works!)
Post #40493
Posted Tuesday, March 02, 2010 7:52 PM
Supreme Being
Main caps were loosened  for the repair. The noise was the flex plate. This engine has run for almost 6,000 miles on this rebuild . The pan was removed for a leaky rear main repair. No damage to the crank or even a mark on the misplaced bearing. They're going to put new mains and rear seal in it....should be good for ever after that!  Barry
Post #40515
« Prev Topic | Next Topic »
All times are GMT -6:00, Time now is 12:36pm
Execution: 0.109. 8 queries. Compression Disabled.
