Supreme Being
Last Login: Wednesday, March 30, 2011 1:40 PM
Visits: 594
| I searched & found everything except valve timing events. I am sure this has varied over the years and after-market manufactures playing ball in the rebuild sector. I am just trying to find a common baseline for tuning purposes.
Supreme Being
Last Login: Wednesday, January 11, 2012 10:11 AM
Visits: 362
| These factory cams have the following B/P specs: ECK-6250-C = B6A-6250-C 246/246 .264/.262" Cam Lift ECK-6250-D = B6A-6250-D 246/246 .264/.264" Cam Lift Remaining timing events are common for both camshafts: 110/116 Lobe Sep IO 12 BTDC @ 0.016" IC 54 ABDC @ 0.019" EO 58 BBDC @ 0.0145" EC 8 ATDC @ 0.0175" Regards, Dennis
Supreme Being
Visits: 594
Thanks Dennis.
Are there any .050 interpretations of these specs, or has anyone done a cam doc on them?
Thanks again.
Supreme Being
Visits: 362
| Duration 196/196 @ .050" Regards, Dennis
Supreme Being
Last Login: 2 days ago @ 7:26 PM
Visits: 769
The 1957 cams were 208 @ .050". One reason why the 57's ran better, along with better heads, intake manifold, carburetor, exhaust and distributors.
Supreme Being
Visits: 362
| However, that was a 256 not 246 duration cam. One could say 1957 was the pinnacle year for the 312 as the high horsepower Ford passenger car engine, with the 332/352 released in 1958MY and the base V8 remaining a detuned 292, then being further detuned in 1960. So how does 246 replacement cam timing compare with the Ford 246 duration cam b/p specs? Regards, Dennis
Supreme Being
Last Login: Today @ 6:56 PM
Visits: 4,319
Both of those cams just goes to show how under cammed these engines were back when new.
-Gary Burnette-
Supreme Being
Visits: 362
| Probably "high tech" for 1957, at least the .400" or so valve lift. The 246 and 256 duration cams were for auto trans passenger car engines. Look at the two factory blower cams, EDB-D 290/290 .446/.446 and EDB-E 302/302 .454/.454, then compare it to what the other auto manufacturers were offering back then. Pretty radical for back then. Regards, Dennis
Supreme Being
Visits: 4,319
That's true, but I'm speaking in general for the size of the engines at the time they could handle alittle more cam even for grocery getters and still keep a smooth idle at say 216-218-220 @ .050 and retain good gas miliage and more power, but from what I've read from the past some owners thought these cars had too much power then and maybe the power was kept down purposely for the family ride with the smaller cams???
-Gary Burnette-
Supreme Being
Visits: 362
| Agree. A lot of potential reasons why Ford didn't use more agressive cam timing, or went back to the 246 duration cam in 1958. Fuel economy, drivability, cost, available manufacturing faciilities and tooling, justify marketing the 1958 332/352 engine (don't want that 292 too fast), etc ... . In the "Ford at Fifty" book, although the caption references a flathead Ford police car. It states "This squad car, a Ford with a special engine, would be dangerously fast for non-police use". LOL!!! I was trying to keep this thread somewhat going, hoping someone would post numbers on the available aftermarket 246 duration cams, if there are any. Curious to see how the numbers compared to the OEM Ford cam, or if they just reverse engineered it. Regards, Dennis
