Supreme Being
Last Login: Sunday, January 29, 2012 5:11 AM
Visits: 1,819
Park Olson (3/8/2010) You need 5/16-24 for the original stud .You sure about that? IIRC, at least on mine, I *thought* that the bolt hole in the head for the stud is coarse thread, and you use that itched stud for the regular valve covers. If you had the t-bird dress up covers you had to get different studs that were coarse on one end (to go into the head) and fine pitch on the other for the dress-up nuts specific to those covers? Is my recollection wrong on that? cars still tucked in for the winter else id go check!
Ron GroveWauconda, IL
Supreme Being
Last Login: Today @ 8:22 AM
Visits: 1,075
Studs for the aluminum T-bird covers are LONGER- diameter & thread size is the same... /Duck
BOO- YA!!!
Last Login: Yesterday @ 5:43 PM
Visits: 2,148
rgrove (3/8/2010) .....I *thought* that the bolt hole in the head for the stud is coarse thread, and you use that itched stud for the regular valve covers. If you had the t-bird dress up covers you had to get different studs that were coarse on one end (to go into the head) and fine pitch on the other for the dress-up nuts specific to those covers? Is my recollection wrong on that? cars still tucked in for the winter else id go check!Here are the dimensions for the rocker studs for the stock metal valve covers:5/16”-18 X 5/16”-24 X 3.86” For the aluminum T-Bird covers the dimensions are: 5/16”-18 X 5/16”-24 X 4.125” Coarse thread at the heads and fine threads for the valve cover nuts.
Forum Newbie
Last Login: Tuesday, May 25, 2010 9:08 AM
Visits: 68
when I changed over to the alum T-Bird covers I used 5/16-18 grade 8 all-thread, cut it to the length needed. That way the coarse thread gives you more options for acorn nuts wing nuts etc. I did it mostly because I had a hard time finding anyone who stocked the correct T-Bird studs.
'51 club coupe 5.0 aod, 55 crown vic 272 fordomatic
Forum Member
Last Login: Monday, November 28, 2011 12:31 PM
Visits: 198
| Thanks for the replies. I found a nice set of enlarged aluminum acorn nuts at restoration shop her in the Netherlands. I am still looking for the wing nut style if anyone finds some. Let me know. I will post pictures of my engine build in the very near future.
Visits: 2,148
Supreme Being
Last Login: 2 days ago @ 1:33 PM
Visits: 2,128
For those of you still looking, I bought some from both sources. The link I noted in an earlier post (with picture) cost me $40 shipped for 2 bags of 4, Eelco brand packaging. I contacted the seller in Ted's link above and got a bulk pack of 8 for $16/shipped. The Ebay seller that Ted listed sells the rough casting, and it isn't tapped for threads, but has a 1/4" hole if I recall correctly. That would be best for a Y-block fella's purpose.
Todd Central California...about half way between Fresno and Sacramento 1956 Thunderbird 1960 F-100 1961 Starliner 312 Y-Block 478" Cadillac 390/375 hp FE
1972 Ford Ranchero GT
