Allright, the updates are gonna start coming again!
Y-BlocksForever Forum
««12
Allright, the updates are gonna start coming... Expand / Collapse
Posted Friday, March 12, 2010 6:22 PM
Supreme Being
Last Login: Yesterday @ 9:17 PM
Posts: 1,959, Visits: 10,356
I'm probably preading to the choir but when I tear an engine down I always put the main caps back on the block to keep them in the right order and on the right main. The caps settle in and like to be matched back where they came from. Unless you are line boring. You never know how long a block will set after teardown so this practice helps keep them right. Just a minor teaching point! Glad it worked out! Chuck in NH
Y's guys rule!Looking for McCullouch bracketts and parts.
Also looking for 28 Chrysler series 72 parts.
 MoonShadow, 292 w/McCulloch 28 Chrysler Roadster (Y in the works!)
Post #41055
Posted Friday, March 12, 2010 7:55 PM
Supreme Being
Last Login: Today @ 12:41 PM
Posts: 2,592, Visits: 27,730
I'll mark'em with a punch before removing them. Number punches if they're handy or a number of dots corresponding with the number of the main cap.
Post #41063
Posted Wednesday, March 17, 2010 9:29 PM
Supreme Being
Last Login: Thursday, October 06, 2011 12:18 PM
Posts: 240, Visits: 1,109
Crank, cam, timing chain in...waiting now to find a new thrust bearing as my Ebay score turned out to be the wrong bearings (.010 under, I need standard)
I will have to post a pic of the oil slinger, looks weird to me but this is my first yblock so...
Post #41351
Posted Thursday, March 18, 2010 7:18 AM
Supreme Being
Question of the day.... our oil slinger has a keyway but it doesnt register on anything on the crank shaft, do we not have the crank gear installed far enough? Doesnt look like it can go any farther, but????
Post #41366
Posted Thursday, March 18, 2010 7:29 AM
Supreme Being
It is held in place by the harmonic damper. I think the key way is in place so it'll fit over that 1st key.
Post #41367
Posted Thursday, March 18, 2010 12:37 PM
Supreme Being
Last Login: Yesterday @ 6:57 AM
Posts: 158, Visits: 759
Like those pics! Keep 'em coming.
Post #41378
Posted Thursday, March 18, 2010 3:26 PM
Supreme Being
If thats the crank you plan to run I'm sure you plan clean off the rust on the end. Just thought I'd mention it. Quick way to a seal leak. Chuck in NH
Post #41381
Posted Wednesday, March 24, 2010 1:19 PM
Supreme Being
Next bump in the road...
kids install the #1 and #5 pistons, go to torque the rod bolts, we used 50lbs-ft. per the James Eikman book. Took the fasteners to 30 first then came back to go to 50. One rod bolt broke and on the other rod it feels like the nut has stripped on the bolt.
This is a brand new Napa torque wrench, I assume it is accurate??
Whats happening? Would hate to install all new rod bolts, I know alot of people do but alot of engines seem to go together fine with the old ones???
Post #41583
Posted Wednesday, March 24, 2010 1:43 PM
Supreme Being
Last Login: Thursday, February 02, 2012 12:35 PM
Posts: 1,255, Visits: 4,934
Dan (3/24/2010)
Dan, there  different personal preferences for torqueing bolts etc, personally i would go 20,35.45 max, rotating crank slightly on each setting to check if bearing hasnt bitten on crank, which will show any clearance problems that may occur.  I believe torque setting is 45 lb and i think you may consider replacing the rod bolts. i would recheck wrench stting. this is only a suggestion as there are other views just as satisfactory. regards bill.
 Down Under, Australia
Post #41584
Posted Thursday, March 25, 2010 9:38 AM
Supreme Being
Last Login: Today @ 10:36 AM
Posts: 1,092, Visits: 3,853
charliemccraney (3/18/2010)
You could likely peek through the timing cover/fuel pump opening to insure the damper is holding the slinger tight.
6 VOLTS/POS. GRD. NW INDIANA
Post #41617
« Prev Topic | Next Topic »
««12
All times are GMT -6:00, Time now is 12:45pm
Execution: 0.172. 8 queries. Compression Disabled.
