Y BLOCK OVERHAUL
Y-BlocksForever Forum
12»»
Y BLOCK OVERHAUL Expand / Collapse
Posted Friday, March 12, 2010 8:35 AM
Junior Member
Junior MemberJunior MemberJunior MemberJunior MemberJunior MemberJunior MemberJunior MemberJunior Member
Last Login: Saturday, July 16, 2011 11:07 AM
Posts: 21, Visits: 41
AM OVERHAULING A Y BLOCK IN MY CROWN VIC.  KNOW THE MOTOR HAS BEEN REPLACED.  NOT SURE OF YEAR ; BELIEVE IT TO BE A 57 TRUCK ENGINE.  CAN ANYONE TELL ME WHERE THE ID NUMBERS ARE AND WHERE TO FIND ENGINE ID?  NEED INFO SO THAT I CAN PURCHASE CORRECT REPLACEMENT PARTS. THANKS
Post #41013
Posted Friday, March 12, 2010 10:19 AM
Supreme Being
Last Login: Tuesday, June 28, 2011 5:11 PM
Posts: 512, Visits: 1,479
Even if you identify the engine, you will still have to pull the engine apart to measure your bore and crank journals. If it is indeed a truck engine, chances are good its not standard. Head casting numbers will tell you the intake valve valve stem diameter, but they could have oversize stems.
Kenneth
Fredricksburg, Texas
Post #41021
Posted Friday, March 12, 2010 10:49 AM
Supreme Being
Last Login: Friday, January 27, 2012 8:52 AM
Posts: 109, Visits: 1,494
A good resource for Y-Block engine block/head ID is John Mummert's site:  http://www.ford-y-block.com/
Gerald Ingram aka "Gritsngumbo"
Monroe, LA
LITTLE RED: 64 Ford F100 Short Bed Styleside
BIG RED: 63 Ford F100 Long Bed Unibody
BBW RED: 61 Ford F100 BBW Long Bed Custom Cab Unibody
BIG “UN: 63 F250 Longbed Flareside
CREW CAB: 63 F100 "Stageway" Crew Cab w/Long "Wrong" Bed
Post #41025
Posted Friday, March 12, 2010 5:23 PM
Junior Member
I APPRECIATE THE INFO.  THANKS
Post #41049
Posted Friday, March 12, 2010 5:25 PM
Junior Member
I HAVE THE ENGINE TORN DOWN.  I WILL START THE PROCESS. THANKS
Post #41050
Posted Friday, March 12, 2010 6:25 PM
Junior Member
SINCE I HAVE THIS ENGINE APART; AND IF I FIND OUT THAT IT IS A TRUCK ENGINE; ARE THERE ADVANTAGES TO KEEPING THIS ENGINE OR ANDY DISADVANTAGES TO KEEPING IT.   OR SHOULD I LOOK FOR A CAR ENGINE AND REPLACE IT??  THANKS AGAIN.
ED
Post #41056
Posted Friday, March 12, 2010 7:59 PM
Supreme Being
Last Login: Today @ 5:41 PM
Posts: 2,592, Visits: 27,736
Work with the engine you have. It really doesn't matter what the engine came from originally. Sometimes it'll have good stuff. Sometimes it won't. You should start by identifying the parts you have.
http://www.ford-y-block.com/technical.htm
Post #41064
Posted Saturday, March 13, 2010 1:07 PM
Supreme Being
Last Login: Yesterday @ 6:57 AM
Posts: 158, Visits: 759
eyks2 (3/12/2010)
ED
The biggest reasons for replacing the engine would begin with considering its general condition, and if there are any major problems with it. I don't think there are any inherent advantages one way or another based on whether the engine originally came out of a truck or a car, because the major components it was born with from Ford would have been the same. It depends on what characteristics your particular engine presents at this time, 50-odd years later.
Post #41082
Posted Sunday, March 14, 2010 5:24 PM
Junior Member
THANKS FOR THE INFO YOU GAVE ME.  I HAVE FOUND OUT THAT I HAVE A 1962 292 HEAVY DUTY TRUCK BLOCK AND HEADS.  THE BLOCK # IS C2AE, THE HEADS # ARE C1TE.  DO YOU HAVE ANY SUGGESTIONS FOR REBUILDING THIS TO MAKE IT MORE SUITABLE FOR MY CROWN VIC.?  BEFORE REBUILD I WAS  ONLY GETTING 9 MPG;  DO YOU THINK THIS IS WHAT I SHOULD EXPECT FROM THIS ENGINE?  I WAS GETTING EXCESS BLOW BY THAT IS WHY I STARTED THE REBUILD.
THANKS AGAIN FOR YOUR ADVISE.
ED
Post #41158
Posted Sunday, March 14, 2010 5:29 PM
Junior Member
THANKS FOR ALL THE INFO AND HELP.
Post #41159
« Prev Topic | Next Topic »
12»»
All times are GMT -6:00, Time now is 7:22pm
Execution: 0.297. 10 queries. Compression Disabled.
