| | | Supreme Being
Group: Forum Members Last Login: Today @ 8:06 PM Posts: 613, Visits: 8,212 |
| I'm about ready to start work on the windage tray and crankshaft scraper. What gauge steel should I use for them? I am getting a screen kit from canton racing products. I need to make a frame on which I can mount the screen?
I found some ARP standoff studs for Chrysler that look like they will work.
Norcross, GA |
| | | | Supreme Being
Group: Forum Members Last Login: 2 days ago @ 4:53 AM Posts: 299, Visits: 1,991 |
| Charlie, I would juess that 18 gauge would work, 16 gauge would be better but harder to work if you are trying to form it. Please take some good pictures and a play by play as I want to try my hand at fab'ing one myself. Good luck!
Glen Henderson
Freedom is not Free
Letohatchee, AL |
| | | | Supreme Being
Group: Forum Members Last Login: Today @ 3:49 PM Posts: 853, Visits: 5,198 |
| | | | | Supreme Being
| Where is Ted? He hasn't been on since the 25th.
Norcross, GA |
| | | | Co-Administrator
Group: Administrators Last Login: Today @ 6:05 AM Posts: 1,014, Visits: 1,194 |
| charliemccraney (4/24/2007) I'm about ready to start work on the windage tray and crankshaft scraper. What gauge steel should I use for them? I am getting a screen kit from canton racing products. I need to make a frame on which I can mount the screen? I found some ARP standoff studs for Chrysler that look like they will work.The one piece sandwich style windage tray used in the 428CJ engines is stamped out of 18 gage material. If making a frame to support the screen material, then 16 gage material would likely be more suitable. I've yet to make a simple windage tray in this design but the EMC engine project would need one that sandwiches between the pan and the block in which to fit the rules. Up to now, I've either installed the windage tray in the pan or incorporated it in the 'main support girdle'.
 Lorena, Texas (South of Waco) |
| | | | Supreme Being
| Thanks Ted.
I have a few more questions. I sent them to you in a pm but I'm not sure if you got it.
I notice that most trays are curved and some are not. Is there any benefit of one design over another? Because of the deep skirted design, I am thinking that a curved tray is not necessary - or at least not much of a curve will be required. The old airhead BMW motorcycles use flat windage trays. Does the distance between the tray and rotating assembly affect how well the tray functions?
How much clearance is required between a crank scraper and the rotating parts? Does a scraper function better on one side of the block than the other.
Norcross, GA |
| | | | Supreme Being
Group: Moderators Last Login: Today @ 3:14 PM Posts: 954, Visits: 2,946 |
| | Charlie and Ted: The scraper I use in the Hurricane sandwiches between the block and pan. I took a piece of thin cardboard the length of the block (not including the timing cover) and about 3 inches wide, and put holes in it so that pan bolts and flat washers would hold it in place. It is on the passenger side of the block. I rotated the engine backwards and trimmed the cardboard as needed to clear the rotating parts. I kept the clearance at about 1/8". I transferred the pattern to some 18 gauge and cut it out. Put it back on the engine and double checked clearances. I left tabs on the scraper that align with the main caps and they rest on the bolt heads. Then I took another piece of 18 gauge the length of the scraper and rolled a radius of about 2" on it lengthwise. I trimmed the rear corner so it would fit into the pan, and fastened it to the bottom side of the scraper. I did this to keep the scraped oil from slamming against the pan gasket, and to direct the oil downward to the pan. I have screen in the pan made from 1/8" hardware cloth. I don't know how much horsepower I gained, but when I installed it my car picked up 1/10th sec. in the quarter. Charlie, put the scraper on the passenger side. If it is on the other side, oil would pile up on top of it and have to keep circulating around and around. John
| | | | Supreme Being
Group: Forum Members Last Login: Today @ 8:21 PM Posts: 445, Visits: 1,642 |
| | If you guys can come up with a sketch, set of dimensions, tin thickness etc. - I'll try to get a good CAD drawing made so that it can be put out in the available Y tech information. We'll just put note on it that it is copyrighted to the site or something. It may need to be handed back and forth a few times for checking to insure it is exactly what it needs to be. A 10th is worth working for if you are a racer - the big gains are probably at the upper end of the rpm band however - not especially street horsepower. Dyno guys would know best. On the other hand - the crank scrapers are a pretty simple part and who knows - maybe it'll be just enough to dust a contender. Here in Tucson, I get sheetmetal shims and plates (often up to .250 thickness) cut by a guy with a Laser - and there are several other businesses around elsewhere that can do the same thing. Lately we have had some heavier harder stuff cut with a 50,000 psi waterjet. They just need a decent drawing to get it set up on XY coordinates. As a lifetime garage dweller - I'd probably try to make my own first....................
Steve Metzger Tucson, Arizona |
