Chem Dip isnt working on the carbs!
Y-BlocksForever Forum
«««123
Chem Dip isnt working on the carbs! Expand / Collapse
Posted Wednesday, December 01, 2010 12:16 PM
Supreme Being
Last Login: Today @ 4:02 AM
Posts: 315, Visits: 4,682
Just finished up cleaning a bunch of 94's. I've always used toilet bowl cleaner as I stated earlier. The carbs look showroom quality as usual. One problem, when stealing the wifes toilet bowl cleaner make sure it's not a "green" cleaner, baby shampoo is stronger.Make sure it contains hydrochloric acid and you'll have shiniest carbs on the block. Gary
       Gary, 55 Vicky, St. Germain, Wisconsin
Post #52381
Posted Wednesday, December 01, 2010 6:15 PM
Supreme Being
Last Login: Friday, May 18, 2012 8:19 AM
Posts: 1,127, Visits: 7,595
About how long do you let the carb(s) soak?
Mike, located in the Siskiyou mountains, Southern, OR
292 powered 1946 Ford 1/2 ton
Post #52390
Posted Thursday, December 02, 2010 5:42 AM
Supreme Being
I don't really soak them, I use a chemical brush, dip them in the cleaner, work the brush into the crevises and rinse it off. Rubber gloves are nice for the large flat surfaces, just rub it and rinse. Been using this stuff for 30+ years. Gary
Post #52406
Posted Tuesday, March 22, 2011 3:35 PM
Supreme Being
Last Login: Monday, May 14, 2012 7:02 PM
Posts: 83, Visits: 549
I saw a thread on the HAMB about vinegar, they were soaking parts in it and removing all rust. Some guys were filling kiddie pools to soak larger items. Plenty of examples to go from, some warned not to use it on aluminum and pot metal. As a plumber I have used it to soak showerheads and aerators, worked great.
thanks, Mark
Post #57011
Posted Tuesday, April 05, 2011 9:53 AM
Supreme Being
Last Login: Wednesday, February 15, 2012 2:16 PM
Posts: 157, Visits: 540
i'll have to remember vinegar trick.
i used that for showerheads as well.
This ain't no L-Kamino!
Post #57583
Posted Friday, April 08, 2011 7:41 AM
Forum Member
Forum MemberForum MemberForum MemberForum MemberForum MemberForum MemberForum MemberForum Member
Last Login: Today @ 6:54 AM
Posts: 27, Visits: 1,058
The product that will work is   " Berryman Professional Chem Dip" Part  #0905    5 gal. is the only way it can be bought. O`Riellys Auto Parts has it at their Brownsburg IN. warehouse & other ones around the country I would think. Other professional auto parts should be able to get it,some of them say they can`t get it. Can you say  "E.P.A." Cost  $90.00 to $150.00 depending price rate you get. This is what I`ve used almost 60 years & it does`n harm any of the metals in carb. or transmision parts.It removes any thing including your skin if you don`t use rubber gloves. Remember if you want to get a can & share it, the top 1/3 of liquid is water that seals it from evaporating. It last for years if that water is on top.  Harry Hutten Jr.
Post #57668
« Prev Topic | Next Topic »
«««123
Forum Moderators: Ted, Hoosier Hurricane
All times are GMT -6:00, Time now is 9:35am
Execution: 0.109. 8 queries. Compression Disabled.
