| | | Supreme Being
Group: Forum Members Last Login: Yesterday @ 2:20 PM Posts: 124, Visits: 592 |
| | Is there a listing of Borg Warner T-85 types manufactured and their applications? I think the OD's are T-85N's and there are R-10 and R-11 versions. Some are passenger car and others are truck applications. Is a R-11 1W a truck version? Thanks Paul J.
Paul J. - '57 E Code |
| | | | Supreme Being
Group: Moderators Last Login: Yesterday @ 5:15 PM Posts: 999, Visits: 3,061 |
| | Paul: I don't know of a list, or know the applications, but I do know the R10s were used on the small transmissions, like the T96, and the R11 was used on the T85s. The R10 planetary set has 3 pinions, the R11 has four, as well as a larger diameter output shaft. John
| | | | Supreme Being
Group: Forum Members Last Login: Yesterday @ 3:55 PM Posts: 981, Visits: 1,704 |
| | Paul, What is the output spline size? I have parts of an r-11 and i know for a fact it came from a truck. Other than the output dimensions and case length everthing else interchanges with my pass r-11. Frank/rebop
Frank/RebopBristol, In ( by Elkhart)  |
| | | | Supreme Being
| | John and Frank, I don't have the T-85's in my possession yet. I'll send info when I have them. Thanks,
| | | | Supreme Being
| | I picked up the two OD transmissions today. I have a picture if anyone would like to look at them. They have a shorter tail housing than shown for a T-Bird. I don't know if Bird OD housings are longer than passenger cars. I can e mail a picture to you if I have your e mail address. I tried to post a picture to the forum and can pull it up, but can't seem to attach it. I am looking for a side plate and the flange that goes around and retains the input shaft. The mounting ears look larger and they have two bolt patterns, probably for differrent applications. Thanks,
| | | | Supreme Being
| The casting numbers on these transmissions are T85N-1B and the OD units are R11-1W. They also have some numbers stenciled on them in yellow paint. It looks like the stencil says 8W3AIS or the last digit could be a 5. The left hand portion of the A could also be a slash mark. They have a U joint type yoke at the end of the output shaft instead of a slip type mating. John F. says this indicates that they are a truck application. I would like to convert them, or one of them, or find a home for them.
