Forum Guru
Last Login: Sunday, February 12, 2012 3:06 PM
Visits: 147
I have a 55 Ford converted to 12 volts. All gauges and senders are original. Gas gauge reading corrrect. The problem is the temperature gauge reads almost all the way over to Hot but engine is not hot. Prior to installation, temp gauge tested correct using 1.5 Volt battery. The temperature sender is fairly new but had a high reading prior to converting to 12 volts. Any suggestions? Thanks,
Gary
Supreme Being
Last Login: Today @ 8:50 AM
Visits: 7,180
Do you have a regulator in the instrument circuit to drop the voltage from 12 to 5 volts?
Forum Guru
Visits: 147
I'm prettty sure the wiring is stock and there is no voltage regulator in the circuit. Current goes from ignition switch to temp guage and fuel guage. From the other temp guage terminal, current goes to temp sensor in block. The other fuel guage terminal goes to fuel tank float/sender. Thanks
Gary
Supreme Being
Visits: 7,180
After '56 Ford installed the instrument voltage regulator in the hot line between the ignition switch and the gauges. Post '56 gauges are 6 volt, as is your '55. A regulator in the circuit should solve the problem.
Forum Guru
Visits: 147
| Hoossier, Thanks for the info! It will be so great to get the thing reading correctly. I really appreciate your help. Thanks,
Gary
Supreme Being
Last Login: Today @ 6:27 AM
Visits: 8,345
