Supreme Being
Group: Forum Members Last Login: 2 days ago @ 11:35 AM Posts: 157, Visits: 637 |
| | " As I said a Monster is truely born! " And our MSD 6AL was set up with only 5000 rpm limiter... I just took oil pan off of the tranny and there is no chips from anywhere in the oil and the oil is clear. So maybe adjusting the rear band will help us.
Get in, sit down, shut up and hold on!
Seppo from Kellokoski, Finland |
| | | | Supreme Being
Group: Forum Members Last Login: Sunday, January 04, 2009 12:16 AM Posts: 870, Visits: 5,232 |
Supreme Being
| We have a cable connection from tranny to the carb throttle plate axle and it is set so that when the plates are at wide open position, the kick down lever bottoms. Should the lever bottom before plates are fully open?
| | | | Supreme Being
| | | | | Supreme Being
Group: Forum Members Last Login: Yesterday @ 9:09 PM Posts: 467, Visits: 1,753 |
| | Here are a couple of shots of the "lost motion" linkage on my '56. The carb throttle hits the internal stops, then linkage contines to rotate in the slot to further lower the Fordomatic pressure control rod.
The transmission control is the lever just above where the screwdriver is inserted and it is rotating downward as the throttle advances. must be another 15° of travel there.
Steve Metzger Tucson, Arizona |
Forum Guru
Group: Forum Members Last Login: Saturday, January 03, 2009 1:04 PM Posts: 63, Visits: 387 |
| | Boy that looks like a lot of fun!! Is this just a Saturday get together? Things have changed over here and people just go their own way. That Sunset on that lake is just absolutley Fantastic! What a shot! Nothin sounds like "Y" Mike
| | | | Supreme Being
Forum Member
Group: Forum Members Last Login: 2 days ago @ 5:05 AM Posts: 32, Visits: 193 |
| It's all-aluminium 2-speed trans from '60 Fairlane and no vacuum modulator. I agree that it needs pressure from that kick down linkage, but as Hollow Head said we don't know how to adjust it because it's now done with cable.
-jyrki from Finland- |
