Help removing Balancer
Y-BlocksForever Forum
Home      Members   Calendar   Who's On
Help removing BalancerExpand / Collapse
Posted Tuesday, August 29, 2006 2:33 PM
Forum Newbie
Forum NewbieForum NewbieForum NewbieForum NewbieForum NewbieForum NewbieForum NewbieForum Newbie
Last Login: Wednesday, August 30, 2006 3:06 PM
Posts: 2, Visits: 4
Trying to dissemble the original 292 out of my wife's 55 Bird.
It appears that the snout of the balancer has been drilled just in front of the timing cover seal and welded. Is this a factory balancing weld, or has the previous owner solved a wear problem by stick welding the balancer snout to the crank??
There are 3 holes, approximately 3/8" spaced at 120 degrees and there is weld in them. We can't get in there to drill out the weld and we definitely can't get the balancer off unless there's some magic process that we don't know.
Post #538
Posted Tuesday, August 29, 2006 5:11 PM
Supreme Being
Last Login: Yesterday @ 9:15 AM
Posts: 118, Visits: 657
John,
Taking the balancer off my 312 was tough. They do fit tight. The only thing that holds the balancer on the crank is the fit "tight" and the crank "key".
The holes you refer to are threaded so you can insert bolts on a puller to remove the balancer.
Now if yours are welded ??? with no threads exposed I would think you could use a puller that would grab the balancer "claw type". Caution as this could pull the balance wheel off the hub which has the key way. That would destroy the balancer.
If you get it off you wouldn't want to put it back on with the holes welded anyway.
Good Luck!
Jim
Jim Rowe
Post #540
Posted Wednesday, August 30, 2006 3:08 PM
Forum Newbie
Posts: 2, Visits: 4
Made a puller fashioned after the resto shops...holes are welded at factory...got the assembly off the crank...
Thanks for the response.
Post #558
« Prev Topic | Next Topic »
Reading This TopicExpand / Collapse
PermissionsExpand / Collapse
All times are GMT -6:00, Time now is 2:37am
Powered By InstantForum.NET v4.1.4 © 2009
Execution: 0.125. 10 queries. Compression Enabled.
