| | | Supreme Being
Group: Moderators Last Login: Yesterday @ 5:15 PM Posts: 999, Visits: 3,061 |
| | Paul: Yes, it's FOM. Frank's Custom 300 is a stick shift. By the way, we're going to another pure stock meet in Stanton MI Sept 15 and 16. John
| | | | Supreme Being
Group: Forum Members Last Login: Yesterday @ 5:45 PM Posts: 143, Visits: 433 |
| | Just a question, but are you sure the issue is with the cable construction? I have had cables that unless properly lubed will cause a bouncing needle as well. Maybe just lube the p*ss out of it with speedo cable grease? Just a thought.... |
| | | | Co-Administrator
Group: Administrators Last Login: Yesterday @ 5:35 AM Posts: 1,108, Visits: 1,243 |
| Something else that contributes to a bouncing speedometer is if the cable doesn't draw up tightly on the back of the head. If the threads get tight before the cable comes up flush to the head, then the cable is still loose which causes some bounce.
 Lorena, Texas (South of Waco) |
