rear main
Y-BlocksForever Forum
Home      Members   Calendar   Who's On
««12
rear mainExpand / Collapse
Posted Tuesday, April 01, 2008 6:42 AM
Forum Newbie
Forum NewbieForum NewbieForum NewbieForum NewbieForum NewbieForum NewbieForum NewbieForum Newbie
Last Login: Yesterday @ 5:38 AM
Posts: 6, Visits: 318
I know this is an old topic but I have a few questions about installing the Best Gasket Neoprene rear main seal and side seals in a 312 engine. This will be done with the engine in the car. There are no nails for the side seals. My questions are; where do I need to add RTV sealer to the main seal and side seals and what amount to try to keep the seal from leaking?
1) Does the rear main seal require any sealer on the outer edge that contacts the block and the retainer? My instructions say only to grease the lip and the back and sides of upper seal half so it can be installed on top of the crankshaft and to do the same for the lower seal half in the retainer. Does the pressure from the retainer create a good seal with the block and the retainer that will not leak?
2) Do the side seals require sealer. In Ted's post below he says to use sealer in the side seal slots and push the side seals into the retainer to force the sealer down to the bottom (top) of the retainer slot. Ted also says to add sealer at the base of the retainer where it contacts the block. This makes sense but what holds pressure on the side seals to make the seal with the block. Do the sides of the side seal that contact the block require sealer? If so, how much and do you coat the entire side seal?
My instructions (Best Gasket) say to apply a thin coat of oil to the block where the side seals will contact the block and that the side seals are installed dry. It also says to install the side seals and retainer together. Then to torque the retainer. Now here is the strange part it say to "smear sealer into and around the bolt holes (OK) and all seams between the engine block and retainer". If the sealer is only forced into the seams from the outside it appears to me pressure would force the sealer out and the sides would leak. Is this the best way to seal the retainer to the block? I have heard that most of the leaks are from the side seals.
Any instructions on the best way to get the seal installed correctly and to seal would be greatly appreciated. Roy
Roy B
Post #11407
Posted Tuesday, April 01, 2008 7:38 AM
Supreme Being
Last Login: Yesterday @ 7:38 PM
Posts: 442, Visits: 5,733
With both of the engines I've put together, I used a light coat of RTV on the main cap surface area - the only side of the aluminum retainer that does not have a rubber seal of some sort. I used thread sealer on the retainer bolts. No leaks of any sort in the rear main area on either of these engines.
I don't think any sealer should have to be applied directly to the rear main seal or side seals. The newer side seals are, for lack of a better term, oversized - once installed they will not fall out. The older style used a nail to hold it in place. Make sure the retainer and block are burr free. Clean off any oil before applying the sealer.
I did find it difficult to get the side seals installed. I'm interested in hearing any tricks for this.
Norcross, GA
Post #11412
« Prev Topic | Next Topic »
««12
Reading This TopicExpand / Collapse
Forum Moderators: Ted
PermissionsExpand / Collapse
All times are GMT -6:00, Time now is 3:30am
Powered By InstantForum.NET v4.1.4 © 2008
Execution: 0.172. 11 queries. Compression Enabled.
