What 4 barrels do you "daily drivers" run?
Y-BlocksForever Forum
Home      Members   Calendar   Who's On
«««123
What 4 barrels do you "daily drivers" run?Expand / Collapse
Posted Sunday, October 28, 2007 6:49 AM
Forum Guru
Forum GuruForum GuruForum GuruForum GuruForum GuruForum GuruForum GuruForum Guru
Last Login: Tuesday, December 30, 2008 11:13 AM
Posts: 58, Visits: 218
Two factory teapots on my 56 T Bird
One short
One stout
I'm a little teapot-short and stout
Post #7977
Posted Friday, November 02, 2007 7:42 AM
Supreme Being
Last Login: Yesterday @ 9:15 AM
Posts: 118, Visits: 657
56 Club Sedan 312 bored 40 over, balanced. Stock ECZ-C heads, 57 dist. , Clay Smith 270 Cam. Ford 57 E Code manifold with two 500 CFM Edelbrocks. Runs Strong. No tuning out of the box carbs.
Jim
Jim Rowe
Post #8090
Posted Tuesday, December 18, 2007 11:59 AM
Junior Member
Junior MemberJunior MemberJunior MemberJunior MemberJunior MemberJunior MemberJunior MemberJunior Member
Last Login: Thursday, December 27, 2007 4:34 PM
Posts: 22, Visits: 30
60 292 Starliner with Red's headers, 3 speed and 57 4bbl intake with a fresh rebuilt 4100 1.08. Idles great, pulls OK, but then it is a stock cam 292 in a big car. I do like the 4100 as far as reliability and tuning goes. I would like to get a manual choke on her to replace the auto. Anyone know of a good source for the conversion?
"Hell hath no fury like a womans' scorn for Sega"
Post #8814
Posted Wednesday, December 19, 2007 1:01 PM
Supreme Being
Last Login: Yesterday @ 11:30 PM
Posts: 243, Visits: 2,404
I used a universal conversion kit on my 2100, which I believe has the same auto choke as the 4100.  They are inexpensive and available at most all auto stores.  Installation is easy.
1946 Ford 1/2 ton with 1956 292
Post #8829
Posted Wednesday, December 19, 2007 6:01 PM
Supreme Being
Last Login: 2 days ago @ 5:47 AM
Posts: 97, Visits: 180
when converting be sure to epoxy over the small vaccumm hole where the choke housing normally draws from.
Some great info can be found on this site & the host seems to be well versed in autolites & all applications including y's.
http://www.network54.com/Forum/88781/
Post #8835
Posted Wednesday, February 06, 2008 9:13 PM
Supreme Being
Ok, so I finally broke down & bought a 600cfm Edelbrock.
Out of the box ran ok, rich, but ok.
Some rod changes, & trial & error on a few springs, & it has so much better response than I ever could get with the 4100's I used I am actually surprised! The only bad thing is now a brake line has decided to burst, so so much for my 240.00 carb!!
Post #9986
Posted Thursday, February 07, 2008 5:53 AM
Supreme Being
Last Login: Yesterday @ 9:02 PM
Posts: 157, Visits: 1,731
I have same carb and also running rich.  Know there will be some difference due to cam, heads, etc but what combination springs and rods  did you wind up using?
TC - Austin, TX
You gotta have the right tools and know how to use them.
Rocklock - Austin, Texas
Post #9992
Posted Thursday, February 07, 2008 11:23 PM
Supreme Being
Bear in mind that the altitude here is a mile high, in addition to the things you mentioned.
It came with a 70x52 meetering rods, & the book says 100 main jets.  (haven't had to pull the top to see the jets) It also came with the orange springs for the power pistons.
I ended up using 73x47 rods with the same orange springs.
Like I said before, the throttle response is what I was most impressed with.  The torque is much improved over anything I had ever been able to come up with before.  By that I mean it is an off idle torque that carries through into the power circuit.
Fyi, I have a 301, with ported c1te heads with 1.78 intakes, e-4 isky cam, 1.6 roller rockers.
Post #10008
« Prev Topic | Next Topic »
«««123
Reading This TopicExpand / Collapse
Forum Moderators: Ted, Hoosier Hurricane
PermissionsExpand / Collapse
