½” Head bolt capability
Y-BlocksForever Forum
½” Head bolt capability Expand / Collapse
Posted Friday, January 04, 2008 7:35 AM
Co-AdministratorCo-AdministratorCo-AdministratorCo-AdministratorCo-AdministratorCo-AdministratorCo-AdministratorCo-Administrator
Last Login: Yesterday @ 5:43 PM
Posts: 3,130, Visits: 2,148
Heads need to be able to use ½” head bolts.  Stock factory heads can be drilled without hitting water so that ½” head bolts can be used.  Likewise should be the same with any aftermarket replacement heads.  One idea is for the head bolt holes to be ½” except for a shoulder at the top to accommodate a 7/16” head bolt.  If using a ½” head bolt, then the shoulder is simply drilled out.  This feature is already on a variety of the SBF aftermarket heads so the heads can be used on either 302’s or 351W’s.
Lorena, Texas  (South of Waco)
Post #9143
Posted Monday, March 03, 2008 2:12 PM
Supreme Being
Last Login: Tuesday, July 29, 2008 7:16 AM
Posts: 287, Visits: 511
If you drill out a threaded 7/16 hole in the block to the recommended bit size for a 1/2" tap, will the bit remove all of the 7/16 threads to leave a clean hole to tap to 1/2"?
Post #10572
Posted Monday, March 03, 2008 4:26 PM
Supreme Being
Last Login: Today @ 7:02 AM
Posts: 1,040, Visits: 5,250
The recommended way is to just run the 1/2" tap into the 7/16" threaded hole. John has used this method and states that it worked fine.
Glen Henderson
Freedom is not Free
Letohatchee, AL
Post #10575
Posted Monday, March 03, 2008 5:26 PM
Supreme Being
Thank you for that info, Glen.
Post #10577
« Prev Topic | Next Topic »
Forum Moderators: Ted, Hoosier Hurricane
All times are GMT -6:00, Time now is 10:34am
Execution: 0.344. 11 queries. Compression Disabled.
