Road draft tube
Y-BlocksForever Forum
«««123
Road draft tube Expand / Collapse
Posted Monday, April 12, 2010 3:54 PM
Supreme Being
Last Login: Monday, January 10, 2011 1:51 PM
Posts: 113, Visits: 212
Just in case anyone comes across this old post...I found why my draft tube was leaking, is was loose from the block and oil was running down the OUTSIDE of tube, only looked like is was from inside tube
Post #42329
Posted Sunday, October 24, 2010 9:16 AM
Forum Member
Forum MemberForum MemberForum MemberForum MemberForum MemberForum MemberForum MemberForum Member
Last Login: Tuesday, May 17, 2011 7:14 PM
Posts: 27, Visits: 77
Where does the draft tube return to on the block what side? Someone put a PCV valve on mine screwed it into the manifold and ran a hose from that to the canister on the back of the motor which I am assuming is the Road draft tube canister... And I am thinking that this is the cause for my Vacume leak symptoms irratic idle...
Post #51143
Posted Sunday, October 24, 2010 7:32 PM
Supreme Being
Last Login: Yesterday @ 9:19 PM
Posts: 720, Visits: 4,578
In case you don't catch my other post,the PCV screwed into the intake in front of the carb is the original factory equipment on a 64 truck.
Paul,
Boonville,MO
Post #51176
Posted Tuesday, October 26, 2010 5:45 PM
Forum Member
PWH42 (10/24/2010)
Where should it terminate on the engine, mine is running back to the cannister just behind the valley pan
Post #51273
Posted Wednesday, October 27, 2010 5:04 AM
Supreme Being
Yours is hooked up right.The line from the valve screwed into the manifold goes to the "cannister"in the valley pan under the rear of the intake manifold.
Paul,
Boonville,MO
Post #51296
« Prev Topic | Next Topic »
«««123
Forum Moderators: Ted, Hoosier Hurricane
All times are GMT -6:00, Time now is 1:50am
Execution: 0.172. 8 queries. Compression Disabled.
